MX4111n data erase question
  • nathicana
    • Aug 2008
    • 330
    I have a Sharp MX4111n that will need a hdd data erase.
    Can someone help me on how to do this and leave the machine running?
    I can't find #*c* keys in order to run sim 62 sub 8. Maybe this machine has a different maintenance mode.
    Or is there is an administrator function to do this?
  • daileyrobn714
    • Jan 2018
    • 31
    Re: MX4111n data erase question
    Tap the version twice, that will open up the keypad
    Sent from my SM-G930V using Tapatalk
    • daileyrobn714
      • Jan 2018
      • 31
      Bottom right corner
      • EasyRider
        • Jan 2015
        • 87
        Have you tried this? Link to previous post. http://www.copytechnet.com/forums/sh...ht=#post715130
        You don't have to reinstall Watermark (copier will code without it) and Manual that way.
        Good Luck!
        • nathicana
          • Aug 2008
          • 330
          Good Luck!
          When I log in with admin and go to security settings I'm not seeing what the link describes. I will look at that again.
          I was going to do the sim 62 sub 8 that formats but leaves the software intact
