Mx-7500 reg_r grnd error when running tc 44-2
  • Sharptech0892
    • Aug 2011
    • 79
    [Error Code] Mx-7500 reg_r grnd error when running tc 44-2
    Can't seem to resolve a error when calibrating a mx-7500, when i do t.c 44-2 I get a error on reg_r grnd, tried a different image density unit, density on each color looks great, any ideas? Bad lsu? Problem I'm having is registration doesn't hold for long and 50-22 needs ran again to fix issue. Thanks
  • mojorolla
    The Wolf
    • 2622
    Re: Mx-7500 reg_r grnd error when running tc 44-2
    The Polaris Pro (6500-7500) has "on the fly auto registration". Turn this off in SM mode and attempt to re calibrate.
    50-10 SWT1 and SWT2, set both to 0 to disable.
    • Sharptech0892
      • Aug 2011
      • 79
      Replacing primary belt and blade fixed it.
