MX 3110 wont print after windows upgrade
  • xring1958
    • 166
    I have a customer that is upgrading their windows 10 OS to version 1803 & 1809 after the upgrade the computers will no longer print to the MX-3110 I checked firmware upgrades and there is nothing new I Called Sharp and they haven't been hearing about and similar issues.
    Any input is appreciated
  • sharphead
    • Aug 2009
    • 285
    Re: MX 3110 wont print after windows upgrade
    What have you tried so far?
    Are there any jobs stuck in the spool. Is adobe up to date.
    • mansart
      • 852
      Can you ping machine?
      Can you pull up the machine web page?
      • xring1958
        • 166
        The customer is a long way from us and I just got the call from their IT. He said machines that havent been upgraded still print. And yes they can ping and log onto webpage I had them check for IP Conflict but there is not any other devices with the same Address.
        • brewster67
          • Jul 2011
          • 167
          From one of the upgraded computers have them login the web interface and do a test print from there. If it prints it is a driver issue.
          • Jack79
            • Jul 2014
            • 312
            I have no printing issues with ver 1809. Download and install driver again. Do not use Windows pre installed driver. Do not also use WSD as this cause a lot of problems.
            • mansart
              • 852
              If able .....
              have their IT check to see if affected machines are printing to IP port or WSD. Definitely use IP
              • ridgemill
                • Sep 2017
                • 190
                If you can, get their IT to log into the web manager and check the job log. If the job isn't being received, get them to re-install the driver on a new print queue.
                If it was received but not printed, make sure that authentication is set correctly.
