Sharp MX501N
  • tcypy1961
    • 773
    [Misc] Sharp MX501N
    This Sharp MX 4501N (not MX501N) copier was working at office it came from according to customer. When move to present location I was told copier would not come on. I turned copier on and noticed the light at the power switch on panel was on but display was dead. I opened front door turned copier off/on and display came to life but then froze at a certain point. Fuser heated up and I could hear copier running but display would not leave its original start position. I removed the hard drive and got no error code. I reinstalled hard drive and reseated all dims. Am I looking at a bad hard drive or board problem(board that hard drive is attached to) ??? Can't access special functions either.
    Thanks!!!
    Keyboard and/or computer having issues
    Last edited by tcypy1961; 03-18-2019, 06:41 AM. Reason: didn't check copier model number input
  • copiertec
    • Jan 2016
    • 2205
    Re: Sharp MX501N
    Seems you tried most of the basics, checking and cleaning DIMMS and making sure all connectors are seated. It's an old box so I would not throw much money at it, have you ran an HDD check or tried a reformat? The least I would try is a HDD if push comes to shove.
    • moose55
      • Mar 2017
      • 143
      Re: Sharp MX501N
      I have had problems with other models not coming up. Reseating the mother board would be first step. I would also look at a bad SD card?
      The Moose is loose!!
      • ntbann
        • Jan 2012
        • 628
        Re: Sharp MX501N
        No SD card on MX4501. Just ROM dimms.
        • moose55
          • Mar 2017
          • 143
          Re: Sharp MX501N
          Not familiar with this particular model. Thank you for setting me straight!
          • ntbann
            • Jan 2012
            • 628
            Re: Sharp MX501N
            I have had the dimms fail and also HDD and Control PWB. Old machine! Hard to throw $ at.
            • tcypy1961
              • 773
              Re: Sharp MX501N
              Copier was moved by customer, floor it was rolled on plus parking lot was not smooth. Could the move have damaged hard drive or loosened a connection???
              • moose55
                • Mar 2017
                • 143
                Re: Sharp MX501N
                It very likely loosend a connection. I've seen it times with Sharps. Any PWB that "connects" into (plugs into) another PWB would reseat first. Easiest way to start troubleshooting it!
                • copiertec
                  • Jan 2016
                  • 2205
                  Re: Sharp MX501N
                  Yes, loose connector or HDD from moving is possible. It's Just a matter of how much time you are willing to put into a 13+ year old copier and how much your client is willing to spend.
