U6-10 on MX-4141n with MX-DE22
  • oeshuron
    • May 2008
    • 259
    Have replaced clutches amongh other things and then tried the desk on a different machine with no issues. Upon returning the desk unit it threw the U6-10 code again. While the DE22 was in the shop we had a different model paper desk on the offending machine with no issues at any point.
    Any idea?
  • mansart
    • 852
    Re: U6-10 on MX-4141n with MX-DE22
    Firmware???? Worth a shot.
    Do a full firmware on the offending machine and DE22
    • oeshuron
      • May 2008
      • 259
      We have reloaded the latest firmware choosing to update all with the offending DE22 attached with no luck yesterday. But yes, thought it was worth a shot as well.
      • Reject Devil
        • Nov 2016
        • 5
        Does the tray Motor lift the paper up? If not i would replace that lift motor. You could take the motor off of a different desk unit to see if the fixes the issue. If the lift motor is working and lifting the paper i would check for a faulty sensor.
        • Tech2002
          • Aug 2008
          • 334
          Had a Paper Deck on a MX4141 that, not sure of the Code but would not pass paper. Found out that the issue was the Innovolt had plugged into it the machine a the Water Cooler. Unplugged the Water Cooler and all was, and has been fine. I think it was in part the Water Cooler was causing low voltage to the MX4141. By the way, this was caught much by accident.
