customer called with MX3070 with error H2-03
  • axyun
    • Aug 2007
    • 1323
    Looked in SM and said upper main thermister open. Can anyone confirm before I go there? Frank
  • OlliK1969
    • Nov 2016
    • 311
    Re: customer called with MX3070 with error H2-03
    Hi
    maybe thermistor or fusing belt unit MX-600FB
    • axyun
      • Aug 2007
      • 1323
      Thank you for your help. Is it unlikely to be lamp or thermostat?
      • ntbann
        • Jan 2012
        • 628
        Open means machine cant see resistance of the thermister. Maybe the fuser isn't properly seated.
        • JR2ALTA
          • Feb 2010
          • 2033
          You can probably reset with Sim 14. Frank, I don't know if you're familiar with these newer SHARPS but the fusers are dogs. There's no web or cleaning system built-in so the belt gets caked up in short order. Belt replacement takes quite a bit of time and if you are unlucky there are some bearings that gets seized up and cannot be removed anyway. So we've been installing the whole pricey unit more often than not
          • jp74msj55
            • Oct 2014
            • 149
            Tech pub about thermistor holder being to far away from belt. New plastic holder for thermistors if you are rebuilding them.
            • axyun
              • Aug 2007
              • 1323
              • Andypraeuner
                • Jun 2013
                • 35
                The double tap of the home button should be fairly brisk and quick or it will think you are just holding the home button which will just give you the copy count screen which will go away in a few seconds or just touch the OK button.
