Mx3110 vibrating noise
  • ash_572
    • Oct 2008
    • 523
  • driving lots of miles
    • Jun 2016
    • 399
    Re: Mx3110 vibrating noise
    It acts like a gear on the drive unit is missing a tooth
    • ash_572
      • Oct 2008
      • 523
      I have already replaced the main drive unit. Thanks
      • JLSam
        • Jun 2015
        • 605
        Pictures would get you better responses.
        Have you tried print stop test? Does the image quality problem happen during transfer? Or image creation?
        Hows the LSU?
        Sent from my ONEPLUS A5000 using Tapatalk
        • ash_572
          • Oct 2008
          • 523
          Hows the LSU?
          Uploaded picture
          • repn1999
            • May 2010
            • 310
            did you use oem drums and mk kits? check the little gear on the back of the drum unit, and make sure the little tit is not broken on them. also check the transfer belt gear and drive gear to make sure the pins in them are not broken off.
