MX4141 squeaking from web unit.
  • Hansen88
    • 1055
    I have been to customer 3 times for this problem. Call for squeaking, noise comming from web. the fuser is still pretty fresh from a rebuild not too many copies ago. The web is pretty dark with toner overall and at the contact point it is heavy toner buildup that is causing the squeaking. If I advance the web to a fresh spot ofcourse the noise goes away. I dont have the book in front of me but there were two different sims that sounded like it would advance the web at a quicker rate. They dont seem to be making any difference because in about a week and a half or two weeks the problem is back. It looks like they are printing full color posters on 11x17 with the wrong heat settings but they say they are not. Customer has had machine for a while and this problem is recent. The fuser itself does not look all overloaded with toner,only the web. I have to go back tomorrow. I am going to double check that all lamps are working,other than that I am not real sure.
  • JR2ALTA
    • Feb 2010
    • 2030
    Re: MX4141 squeaking from web unit.
    We had several new fusers shipped that would do this fairly soon after install. The chain of 3 or 4 small gears on the fuser that interlock with the web weren't seated nicely (tooth on tooth) causing them to get smushed. The web couldn't advance. We had to replace the gears.
    Yours was rebuilt but maybe the web ass'y wasn't installed just right and now the gears are damaged.
    Something to look at.
    • Hansen88
      • 1055
      JR2ALTA I think you were right about those gears. I read a recent post about this but I didnt think my symptoms were the same. I did replace all those web drive gears and I believe that is gonna fix the problem. Thanks
      • EasyRider
        • Jan 2015
        • 86
        I've had several of that series in the last couple of weeks do exactly the same thing you noted. Wait a week later and they call back with the same problem.
        I tried making the web move a bit more, and even a different fuser unit. Same thing.
        I changed the web motor (section 38, item 18 in the parts manual) the one with the yellow sticker, have not heard back in two months.
        YMMV
        • Hansen88
          • 1055
          YMMV
          Thanks for the reply,just to try to put a stop to this problem I replaced everything from the web motor and gear in the delivery unit,all the gears in the fuser and we had a new web unit so I put that on too. With the fuser out I can rotate the web with the gear by hand and I couldnt turn the gear by hand before so I think it is good now.
          • danceswrabbit
            • Dec 2013
            • 65
            had an aries do this at a customers doing 11x17 drawings. Got them to run their 11x17 as heavy 1 and havent been back for that.
            • Hansen88
              • 1055
              Thanks for the reply. This customer has had the machine for a while now.,It is a church and they do their weekly bullitens. We have the thick paper settings and all that stuff down-was a prob in the beginning. But this problen is something that has just developed recently. Time will tell but I think it is good now.
              • repn1999
                • May 2010
                • 310
                I would suggest replacing all the bearings at rebuild and use krytox xht-s or gpl205 grease on them and all the gear shafts. never getting any noise problems unless its the web motor that needs replacing. generally we run the units as follows. newfuser > replace web and clean scraper blade at first cycle end > next cycle end full rebuild and new bearings and scraper blade> run one more cycle to where you would replace the web and just replace the unit. I have found doing this is about as far as they will go before developing H4 issues or making it too costly to continue the rebuild cycle.
                • Hansen88
                  • 1055
                  Well, this problem came back today.I made sure the web would advance in the web check sim and it did. I put a pen mark on the web and when cust called back today the mark had not moved. I dont get it. I replaced the motor,it was used but a working machine. I replaced all the gears from the web motor down with new gears. I put a brand new web unit on there. Not sure what else is left.
                    • 14479
                    Did you clear the web counter after replacing?
                    • bilyahn
                      • Dec 2006
                      • 1470
                      I have had this happen a few times and I finally changed the sim 43 settings on the web advance to move after every job and to move after 50 copies/prints. Seems to help but if they are doing full color posters/prints it will still happen periodically. I don't change the number of cycles it runs haven't really found a need for it yet. I would also check your orange sponge roller for toner buildup that comes through the web. This will cause the web to stick and not advance. This will run the web out pretty quickly though.
                      Good luck.
                      Bil
                      • dsmith46
                        • Oct 2016
                        • 81
                        Try checking out TT-012916_2. It was a bulletin Sharp put out for the MX3140/3640 series color machines. But it deals with the same issues. When doing heavy amounts of toner coverage pages, the web just build up. This bulletin addresses this by changing how fast and how much web to advance after each job or set of jobs. You may run through the web roller a bit quicker, but at least not be called out every week or so because of the annoying squeal that this causes. I have adjusted the settings for the series mentioned in the bulletin as well as series of machines you are working on.
                        Good luck!
                        • Hansen88
                          • 1055
                          Thanks for all the replies. I have reset the web counter. Sharps site seems to be down right now so I have not looked at TT-012916_2 yet. I did talk to sharp tech support and he gave me settings to change to that I suspect are what is said on the service bulliten. I will check when I can get onto their site. So now I will wait and see if it comes back or not.
