Sharp AR 5516 bypass problem
  • nkprl
    • Sep 2013
    • 21
    Syptom : bypass fail to feed the paper , it takes the paper 5 cm in and then stucks.
    Changed the Manual feed pick up roller (NROLR1267FCZ1) and cleaned all the system including (NROLR0922FCZ2) Manual paper feed roller. Also changed the Roller arm spring. The problem begun after a paper with paperclip was inserted in the bypass tray. the paperclip removed but the problem remains.
    Any help?
  • JParker
    Technician II
    • Jul 2015
    • 51
    Re: Sharp AR 5516 bypass problem
    What is your jam code, as indicated on the printout from 23-2?
    • nkprl
      • Sep 2013
      • 21
      At 22 - 03 i get A1 code
