SHARP MX M283N Laser Fan Keeps Burning Out
  • mlbcopiers
    • Oct 2007
    • 34
    My customer keeps getting the L4-34 code. I have replaced the fan twice in a month now.
    Are there any other reasons for the fan to go. Should I look at a power supply or something.
    Thank you for the help.
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: SHARP MX M283N Laser Fan Keeps Burning Out
    I would try a PCU board. Typically boards don't cause intermittent problems, unless the fan circuit overheats.
    • mansart
      • 855
      When this code appears....
      Go to SIM 6-2 and activate LSUFM
      Does fan operate? If yes then the fan itself is good, it is signal to/from PCU causing issue.
      Manual indicates it is either fan or PCU board
