Sharp MX-M904 Still Good?
  • acribari
    • Aug 2015
    • 45
    Is the Sharp MX-M904 Still a good Machine. I found one new in the box from 2017. Never open. Comes with standard finisher and high cap trays.
    Couple of questions:
    1. Is this a good machine to sell to a print shop that does 300K per month B&W ?
    2. Does the New in box machine come with toner and developer for the install?
    3. Is the rip built in on this model?
    4. Do I need a laptop to service this machine or is the service documentation on PDF?
    5. Where can I find a service and parts manual for this model?
    6. What is a good vendor for parts? I use precisionroller.com, Copiersupplystore.com etc... Any others recommended?
    Should I go with this machine or a Konica 1100 B&W ?
    Main concern is service documentation and parts availability on the Sharp. Can I still get all the parts ?
    I hope I don't need a laptop to service it like some other companies.
    Responses would be greatly appreciated.
    Thank You
  • bilyahn
    • Dec 2006
    • 1470
    Re: Sharp MX-M904 Still Good?
    We like this series machine. This is the 2nd generation and made some improvements. Will do the 300K/month no problem. We only have 2 of these but have held up well in a school environment. Finisher is just okay. Problems with the SD card so I would be sure to make a copy but that seems to be standard for Sharps at this time. Parts are still available and should be for another 5 years at least. We're a Sharp dealer so no problem with parts/supplies. Does not come with toner or developer. You do not need a laptop to service unit.
    Good luck
    Bil
    • acribari
      • Aug 2015
      • 45
      Good luck
      Bil
      Thank you very much for the response. I will be selling this machine to the customer this coming week. Where can I get a spare SD card? Is it just any SD card or do I need a specific brand and size ?
      Thanks again.
      • copiertec
        • Jan 2016
        • 2207
        Use HDD Raw copy tool, import the setting from the O.G. sd card from the copier on to your computer than rewrite it to SanDisk ultra 16gb class10 sd card, these are the sd cards we use.
        • acribari
          • Aug 2015
          • 45
          Ok, Thank you very much for the tip. Where can I find the HDD raw copy tool ? Is it on the machine already ?
          Thanks again.
          • moose55
            • Mar 2017
            • 143
            Thanks again.
            The HDD raw tool can be downloladed from the internet to a laptop. Just google it.
            The Moose is loose!!
            • acribari
              • Aug 2015
              • 45
              Ok, thank you. I googled it and downloaded both the installer and the portable versions.
              Thanks again.
              Lots of great info.
              • acribari
                • Aug 2015
                • 45
                I finally got the machine delivered. the main body is brand new and works great.
                I have an issue with MX-LC13 high cap that is attached. It is used and it gives me an error to check the cables. I
                t sees the high cap and shows the trays on the display when I select one of the trays it tells me to check the cables.
                Any clue?
                I am new to sharp machines. I have been a tech for 29 years on Xerox and then Konica. Not many Sharps.
                I didn't really troubleshoot it yet but looking for a clue before I go back to the account.
                Thanks. Any help would be much appreciated.
                • acribari
                  • Aug 2015
                  • 45
                  I did read on this forum about a possible firmware update. Where can I find the firmware to download it and copy it to a USB memory stick?
                  • acribari
                    • Aug 2015
                    • 45
                    it turns out that the high cap plug that was connected to the main body was making a loose connection. it now feeds paper. I will also update the firmware anyways just to be up to date.
                    Thank you all for all the good info.
                    Much appreciated.
                    oh, one thing I am missing on the machine is on the main unit. When the high cap feeds paper it goes in to the main unit and then travels up through a transport. the transport door, top side, is missing. is there a part number to order one of these?
                    Paper stops as soon as it enters the main unit obviously.
                    I am looking around for one and made a few calls to see if I can locate one. If anyone knows where to get one please let me know.
                    Thank You.
                    • spanky
                      • Sep 2012
                      • 468
                      You must install a bypass tray, the MX-MF11 since you have the MX-LC13 attached to the machine.
                      • acribari
                        • Aug 2015
                        • 45
                        Ohhhh. Ok, thanks for the info. I will look around for one or if anyone has one let me know.
                        • acribari
                          • Aug 2015
                          • 45
                          Wait, I do have the bypass tray on the MX-LC13. It's mounted on the top of the two trays. I just don't have the door or the transport for the main unit. So when paper feeds from tray 5 or 6 it stops on the feed rollers in the main unit because there is no upper transport with idlers to push down on the feed tires. Paper just lays in the feed tires and declares a jam. I need the upper part of that section. Is there a part number for it ? or does it actually come with the bypass tray ? Either way I need one.
                          Let me know what I can do to get one if you have any idea. I am looking around other places that may have a parts machine I can get it from.
                          See the pictures attached. The finisher in the picture was replaced with the Fn-22 and the Fn-21 was removed.
                          The picture of the right side of the main unit shows no upper transport over the entrance feed rollers. This is what I need.
                          • ZOOTECH
                            Senior member of CRS
                            • 3375
                            You may need the LCT Mounting kit (RB16), if I remember correctly.
                            • acribari
                              • Aug 2015
                              • 45
                              ok, thanks I'll take a look and see if I can locate one.
                              If anyone knows where to get one let me know.
                              Thank you all.
