MX-3570V Duplex misfeeds
  • JPazy
    • Jul 2019
    • 30
    [Jamming] MX-3570V Duplex misfeeds
    I have a Sharp MX-3570V which misfeeds intermittently when duplexing jam code APPD2_S.When it jams it accordians between MFP duplex guide and Right door duplex guide past the second Duplex drive roller. Occasionally it crease the paper an inch and a half from lead edge, like too much Registration Loop. We have installed updated sensor springs, replaced sensors and guides with no resolution to the problem. Machine runs fine in 8.5 x 11 R direction and seems to run fine when outputting to Right Side Tray. Any ideas?
  • Hansen88
    • 1066
    Re: MX-3570V Duplex misfeeds
    There is a technical report CCE-2003R2 out for what looks like your problem. It is for modification of ADU enter/exit paper actuator spring. It sounds like the actuator sticks causing jam and they have a new spring out to prevent that problem.PN of new spring is MSPRD4699FCZ1
    • Hansen88
      • 1066
      Sorry, missed where you said you installed new sensor springs, Thats all I have on that problem.
      • ricohrice
        • Dec 2008
        • 42
        I know this sounds wierd... but what is your firmware level? I've found in some rare cases that updating the firmware on these models fixes some duplex jamming issues.
        • mansart
          • 852
          Check and double check the ribbon cable from right side door to PCU......
          You may want to try adjust for curl, see link below...compliments of mojorolla
          Paper Curl Adj
          • JPazy
            • Jul 2019
            • 30
            Thank you, yes double checked firmware is up to date and reflashed it to be certain. Checked ribbon cables, and reseated them. Don't see any damage on the cables.
            • ZOOTECH
              Senior member of CRS
              • 3375
              Does this machine have a right side exit tray? I saw the cable/connector for the reverse solenoid not properly routed causing the solenoid to not fully open.
              • JPazy
                • Jul 2019
                • 30
                Yes, it does have the Right Tray unit, which I haven't experienced any misfeeds when the paper outputs to that tray. I did remove it and installed the original blank guides, but misfeeding during duplex continues. Thank you for the tip, i will check the wiring harness for the solenoid to be sure it's routed correctly.
