SHARP MX2614 - NO POWER!!
  • Kenny
    • Jun 2009
    • 516
    Hi guys,
    we have a sharp mx2614 at a customers which will not power on. The LED light that is next to the colour and BW buttons is flashing on/off.
    we have cloned an SD card from a good working machine and replaced the card in the customers machine but still no power?
    is it worth trying a new MFP board or power supply?
    any suggestions will be much appreciated.
  • repn1999
    • May 2010
    • 310
    Re: SHARP MX2614 - NO POWER!!
    Probably dc power supply. Could be sd card but only had that like once. 20 something other times was dc power supply
    • Kenny
      • Jun 2009
      • 516
      Thank you for your help.
      can you confirm the below is the correct part number for a dc power supply:
      RDENC0136FCP3
      • moose55
        • Mar 2017
        • 143
        RDENC0136FCP3
        per HyTec, these are the models this DC power supply fits....
        SHARP MX2610N
        SHARP MX3110N
        SHARP MX3610N
        SHARP MX3116N
        SHARP MX2615N
        SHARP MX3115N
        SHARP MX2616N
        SHARP MX2310U
        You have listed that you have an MX-2614? I'm being switched from Sharp to another model line, and correct me if I'm wrong, but I don't recall Sharp producing a 2614? I am familiar with MX-2610, and 2615's?
        The Moose is loose!!
        • Kenny
          • Jun 2009
          • 516
          SHARP MX2610N
          SHARP MX3110N
          SHARP MX3610N
          SHARP MX3116N
          SHARP MX2615N
          SHARP MX3115N
          SHARP MX2616N
          SHARP MX2310U
          Yes it is a MX-2614
          • Jhonjon
            • Sep 2013
            • 208
            SHARP MX2610N
            SHARP MX3110N
            SHARP MX3610N
            SHARP MX3116N
            SHARP MX2615N
            SHARP MX3115N
            SHARP MX2616N
            SHARP MX2310U
            part number seems correct depend on your region.
            • repn1999
              • May 2010
              • 310
              fixed this issue many times....always dc power supply. there is an updated part which seems to fail much less. hytec is a cheaper option but you may get another old style unit.
