New sharp colors/ mx3070 / 3071 etc
  • fireater
    Repair God? not quite
    • Apr 2006
    • 253
    Hey guys .. any thoughts on the fuser in these things?
    the lack of web is still an issue in my mind.
    BUT some do work . others do not. Yes I've done the sharp bulletins.
    Sharp Canada told us that the machines shipped to them before product launch had webs.
    I was wondering if anywhere else in the world they still had webs and if so can i get the parts list of cleaning unit to add it to my machines?
    I fix copiers ...Well Sorta
  • dsmith46
    • Oct 2016
    • 81
    Re: New sharp colors/ mx3070 / 3071 etc
    I haven't heard anything about Sharp adding web units to these fusers. It's a shame, really. The machine's aren't that bad, but the fusers just suck. I have very few that make it to a PM cycle, and I have well over a 100 that I service. If it only had a web, I believe they would last quite a bit longer.
    • fireater
      • Apr 2006
      • 253
      i know and the stuff to run the web is there on the 4070 series. just needs the gears and lever . i dont even care if there is firmware to make the web end sensor work. the web would last as long as the fuser thats all thats required
      • fireater
        • Apr 2006
        • 253
        is there any way we can put pressure in sharp usa? im from canada and they are too small to make this an issue
        • bilyahn
          • Dec 2006
          • 1470
          You would think that some of these mega dealers would have done that already. I was thinking of trying an oil roller from the AR610 series or the ARM550 fuser (2nd generation mod had an oil roller I think) but not sure if this would work and don't have any in stock to try.
          • chubblies
            • Jun 2011
            • 155
            The fusers are utter shite. Sharp have never made a decent fuser, apart from the Hercules, and that is a Ricoh fuser anyway
            • ricohrice
              • Dec 2008
              • 42
              We have eliminated most of our fuser issues with these machines by running the fuser cleaning mode in system settings\image quality adjustment\fuser cleaning mode.
              I run the adjustment at every **70/**71 service call, if the fuser is real bad you may have to run the adjustment a lot (40/50 times). I've brought fusers back to life that i originally though were dead just by running the cleaning.
              • blackpanther
                • Nov 2017
                • 16
                The fuser cleaning mode definitely helps. What also helps is going to simulation 43-1 and put the "plain pap&wup&rdy GR" on -5
                • pbbsinc
                  • Nov 2005
                  • 92
                  Using the 607 kits instead of the 407s to rebuild the 30 - 40 ppm fusers helps a bit as well.
                  We tried it on a couple, half-expecting warmup related codes, but haven't encountered any thus far.
                  • fireater
                    • Apr 2006
                    • 253
                    did you mean the 608 kits?
                    my manual says fuser kits are
                    mx607fb
                    mx607lh
                    but the mx607fb has been superceded by the mx608fb
                    but issues are still occurring.. mainly buildup on the separation plate. and lower heat roller contamination
                    • Nachoman4life
                      • Oct 2007
                      • 212
                      Agreed.. A web is needed, and the 361fb, was WAY more durable than the mx60X, series belts are..it's a shame on Sharps part..
                      Where the heck is my spring hook?
                      • Nachoman4life
                        • Oct 2007
                        • 212
                        No a properly maintained 4110, style belts usually make full life.. 200k
