Sharp MX-3570 Operation Panel blank
  • chatkal
    • Aug 2015
    • 47
    Hi guys! Need help!
    Sharp MX-3570N - Operation panel is blank, but copier boots normally and if you tap the place on the Operation Panel where "Copy" icon resides the copier makes copies.
    When you print from PC - it prints. Web page of the copier is accessible as well. It just Oper Panel that gives problem.
    Operation panel ass'y and LVDS PWB replaced
    Flat cable from MFPC to LVDS PWB replaced.
    Harness from MFPC to LVDS - replaced
    MFPC board - replaced
    DС PWB - replaced
    Fuser F10 next to CN33 on MFPC - OK
    Still no effect. Operation Panel stays blank
    Any ideas?
    Thanks in advance!
  • repn1999
    • May 2010
    • 310
    Re: Sharp MX-3570 Operation Panel blank
    was this a new LVDS board or one from Hytec? we had one that was bad from Hytec. Same symptom.
    • chatkal
      • Aug 2015
      • 47
      It was the board from the working identical machine. Same model.
      • moose55
        • Mar 2017
        • 143
        Msata card?
        The Moose is loose!!
        • pmillard
          • Jun 2019
          • 2
          Originally posted by chatkal
          Hi guys! Need help!
          DС PWB - replaced
          Any ideas?
          Thanks in advance!
          SCN MFPC PWB CN33 P38 CCFT is back light which goes to CN1 P3 of LVDS PWB, if everything works but no light check this. Then check CN 5 P7 of LVDS PWB to CN5 P6 of LCD
