I've got a 5050v that we're supposed to connect an ITC Systems 5400 series coin op. I cannot seem to configure it properly. I've tried various settings within 26-03 (Auditor settings) as well as various settings within the ITC 5400 setup.
Does anyone have the proper configuration for these two systems to communicate properly?
I do have the correct cables connected and I do have enable/disable functionality when I drop a dime in the machine. For instance:
B/W copies are .10 and Color is .25.
I drop a dime in and the copier enables copy function. However it won't increment the clicks to the coin op. You can make 1000 copies with just one dime. It never disables after the alloted clicks (the coin op still says that you have 10 cents inserted).
You can also make color copies with just a dime.
Sharp Technical support had no suggestions other than contacting ITC Systems. ITC Systems gave me their suggested configuration. However, this still isn't functioning properly.
Has anyone had success with these two units being configured to work properly?
Dan
Dan
