Looking for a little help on our Sharp MX-5141N machine. We were overdue for color developer replacement, at the same time Cyan developer became depleted and started causing stripping on the prints. Replaced all CYM developer and performed recommended sims. Worked great for about 2000 pages, however the Cyan developer is now depleted again. Anything I should check or replace to find the root of the cyan developer depleting so quickly? Thanks for your help!
MX-5141N Depleted Cyan Developer After Replacement
Re: MX-5141N Depleted Cyan Developer After Replacement
Unfortunately this is a known issue, Start by replacing the drum and charge and see if that helps, we had two 4141 machines doing this and this fixed one of them and the other we ended up replacing the MFP power board. -
Hello, thanks for the info! So I could replace the MX-5141N OPC Drum Unit and is it correct that the main charge unit is built in or is that separate? Also, do you know if there is any way to get just the Cyan developer, or is only sold in complete kits? Having a hard time finding just Cyan developer!Comment
Hello, thanks for the info! So I could replace the MX-5141N OPC Drum Unit and is it correct that the main charge unit is built in or is that separate? Also, do you know if there is any way to get just the Cyan developer, or is only sold in complete kits? Having a hard time finding just Cyan developer!.
Thanks for the reply again! Okay great, I will give that a shot. Might just swap the whole thing out. I am the unofficial office printer and copy machine technician, along with my full time job... My theory is the color developer is all the same and some guy in finance at Sharp suggested they put a little of each color toner in it, so it is no longer interchangeable!Comment
Yes I followed the service manual and confirmed the clearances and performed the recommended sims. I assume that is what you are referring to?Comment
Also make sure to replace the waste toner container!!! What happens is that the waste toner is not replaced causing the foam seals on it to get smashed down, and deformed. This results in waste toner/developer getting "blown" back into the PCU, hence you get a build up on the charge grid. This causes the developer to be sucked out of the developer unit (the charge grid arcs to the drum). This is why you MUST replace developer, PCU (or rebuild) and waste toner container together when this happens. If you just do one or two of these 3 things, you are not fully rectifying the whole problem.The Moose is loose!!Comment
Also make sure to replace the waste toner container!!! What happens is that the waste toner is not replaced causing the foam seals on it to get smashed down, and deformed. This results in waste toner/developer getting "blown" back into the PCU, hence you get a build up on the charge grid. This causes the developer to be sucked out of the developer unit (the charge grid arcs to the drum). This is why you MUST replace developer, PCU (or rebuild) and waste toner container together when this happens. If you just do one or two of these 3 things, you are not fully rectifying the whole problem.Comment
If you have a yellow developer you can use it. Put it in the DV unit and run 25-2 as normal. Then run sky shots until the yellow toner that is in the developer is replaced with cyan. Then go back in and run your normal calibration procedure. Takes a bit but saves lots of cash.Comment
Looking for a little help on our Sharp MX-5141N machine. We were overdue for color developer replacement, at the same time Cyan developer became depleted and started causing stripping on the prints. Replaced all CYM developer and performed recommended sims. Worked great for about 2000 pages, however the Cyan developer is now depleted again. Anything I should check or replace to find the root of the cyan developer depleting so quickly? Thanks for your help!Comment
Replaced the whole drum unit, waste bin and used the yellow developer we had on hand. Took about 75 pages front and back to get the yellow to green. Good enough to start printing our user manuals again as it continues to transition to blue. Much cheaper than buying a whole developer set. Thanks for your help. Ill let you know in a week or two if this fixed the depletion issue. Thanks again!Comment
