MX-6070N Copy Quality
+ More Options
Posts
  • sharptech21
    • Aug 2019
    • 2
    Hello,
    We have two 6070's in our office right now one with 1m and the other with 60k copies. They both exhibit the same grainy quality on prints, even internal test prints. We've tried changing developer, cleaning density sensors, inspecting all the transfer parts. Nothing seems to improve it. I've run the calibration sims a few times on each without any change. Any ideas on what it could be?
  • driving lots of miles
    • Jun 2016
    • 398
    Re: MX-6070N Copy Quality
    I would replace the main charge kit and drum first.
    • pmillard
      • Jun 2019
      • 2
      Depending on environment, I would suggest checking/cleaning laser window
      • mansart
        • 852
        Print a sim 64 pcl and ps sheet, scan and post.
        • sharptech21
          • Aug 2019
          • 2
          I scanned the images but the site won't let my upload pdfs for whatever reason. I spoke with a senior tech about the issue and he said that this is just an inherent issue with the 6070's which I find hard to believe but he knows what he's talking about. Another tech advised me to change the developer because he recognized the symptoms but that didn't help.
          I found out from a co-worker who uses the machine that the drum units and fuser were changed as of about a year ago. The maintenance counts were not reset in the machine but she's certain that the work was performed.
          Could this be a software issue? The firmware is up to date and I factory reset the machine before testing to make sure the settings were correct.
          I uploaded the images to docdroid but I understand if thats not a trusted site.
          PS: 6070N_PS.pdf | DocDroid
          PCL: 6070N_PCL.pdf | DocDroid
          Grain: 6070N_grain.pdf | DocDroid
          Thanks for your replies!
          • OlliK1969
            • Nov 2016
            • 310
            Hi
            1. check 50-22, all ok?
            2. Change fuser unit for test
            • doyvid
              • Aug 2019
              • 56
              Yes. It's very important for the drum and dev counters to be accurate. The machine uses these for its process control and uses different voltages and amounts of supplies to compensate for wear. You may get other weird seemingly-unrelated trouble codes and errors if you leave them as-is. It sucks but I'd just replace the drums again and make sure to clear the counters.
              • mansart
                • 852
                If you do a magenta "sky shot", and panic stop the machine, is the graininess visible on the primary transfer belt prior to it transferring to paper?
                • dsmith46
                  • Oct 2016
                  • 81
                  Hello,
                  Unfortunately, from my experience with this series, the pics look normal to me. New DV, drums, mk kits should help fill them in a bit better. Make sure to do a full color calibration as well. Sharp machines just do not have that great of a color fill, compared to some other brands, IE..Ricoh. One thing that MIGHT help is to adjust the registration roller and fuser speeds. By slowing them down a bit, it pulls the paper a bit tighter against the primary belt. I've done this on a MX2640 with pretty good success.
                  Good luck!
                  • repn1999
                    • May 2010
                    • 310
                    Dumb question but are you using SHARP Genuine toners in this machine and not aftermarkets? Also is firmware updated?
