Sharp mxm 623
  • davebtech
    • Apr 2015
    • 176
    Sharp mxm 623
  • Hansen88
    • 1065
    Re: Sharp mxm 623
    Usually I will put a pen line across the rollers to tell if they have turned or not. I have not had any drive issues on that model,does not mean there cant be one though. I had one the other day where the paper would not feed out. I saw with the pen line the rollers were turning. It turned out that some paper in the middle of the stack,about a quarter inch thick had bent over corner causing problem. Paper looked fine till I removed it from tray and saw that. I also saw no feed caused by bad rollers that were worn but did not look worn enough to cause no feed at all,but the new rollers fixed it.
    • CopierTechofOmens
      Agitating Artificer
      • 268
      Re: Sharp mxm 623
      There are 2 one-way clutches that weep oil and can slip on each feed assy. Also check to see if the trays are lifting to the correct position.
      sigpic
      • doyvid
        • Aug 2019
        • 56
        Re: Sharp mxm 623
        How many copies on your machine? Those clutches usually start failing around 1.5-2m, but sometimes randomly too.
        • davebtech
          • Apr 2015
          • 176
          Re: Sharp mxm 623
          800 k on it ever see any of the white drive gears kick out at the collar?
          • repn1999
            • May 2010
            • 310
            Re: Sharp mxm 623
            check torque limiters in the lcc1 and lcc2 trays and replace the tandem paper feed drive unit. the tandem drive unit has been a common point of failure since dragon1. also do 50-28 setup auto adjust when new unit is installed.
            • davebtech
              • Apr 2015
              • 176
              Re: Sharp mxm 623
              Thanks!what is Dragon 1 though.......? Where do you get the drive units from and how much? thanks Dave
              • doyvid
                • Aug 2019
                • 56
                Re: Sharp mxm 623
                To clarify, I'm talking about the clutches in the tandem drive unit.
                • davebtech
                  • Apr 2015
                  • 176
                  Re: Sharp mxm 623
                  Thanks for info,how much of a beast is it getting that drive unit out and then clutches ...... drive unit looks like 200 vs 70 bucks for 2 clutches.....
                  • doyvid
                    • Aug 2019
                    • 56
                    Re: Sharp mxm 623
                    It's more work getting the tandem drive pack out than it is to rebuild it. Lots of connectors and screws, gotta remove a fan, big motor, swing the lower right board out of the way, etc. Replacing the clutches will be slightly annoying (to line everything up) but overall quite easy. The unit comes with 4 clutches, so that's part of your price difference. Might be worth changing all 4 if customer is keeping the machine for a while. Haven't seen other components of unit fail before - just the clutches - so rebuilding is fine. Be advised the lower white tray liftup motor tends to come unplugged when you remove the unit - it's easy to miss. You're probably looking at a 75-90 minute job to do everything carefully the first time.
                    • davebtech
                      • Apr 2015
                      • 176
                      Re: Sharp mxm 623
                      • doyvid
                        • Aug 2019
                        • 56
                        Re: Sharp mxm 623
                        Glad to have helped. Hope it solves the issue.
