Sharp mx-2640 light copies but prints ok
  • outdoorkatie123
    • Feb 2017
    • 50
    Hi anyone any ideas have a couple of mx2640 and they are producing light copies but prints are fine
    both machines have had complete services optics laser every thing cleaned
  • woko
    • Jun 2017
    • 44
    Re: Sharp mx-2640 light copies but prints ok
    Have you calibrated the machine (sim 46/74) ?
    • copiertec
      • Jan 2016
      • 2205
      Have you gone into system settings, storing/calling of system settings and restored defaults? Also, have you locked in your SIT chart settings?
      • outdoorkatie123
        • Feb 2017
        • 50
        Hi yes tried both solutions suggested
        • sharphead
          • Aug 2009
          • 285
          Which sims do you use when calibrating?
          Make sure the optics are clean and keep calibrating until it looks good.
          • ntbann
            • Jan 2012
            • 628
            Did someone go into 46-2 and change the settings? Or in system settings and change default copy exposure?
            • repn1999
              • May 2010
              • 310
              clean the optics with alcohol and a soft white cloth. do not use any chemicals or colored rags. this should fix it.
              • outdoorkatie123
                • Feb 2017
                • 50
                Thanks for your reply,we are supplied with blue cloths and glass cleaner but ill try white and alchohol
