Sharp mxm 264 sd cards
  • davebtech
    • Apr 2015
    • 176
    Bought sd card reader and some blank scan disk cards forgot the method to actually copy / format these.... any help appreciated Dave
  • mansart
    • 852
    Re: Sharp mxm 264 sd cards
    Download HDD Raw Copy
    With a good card in reader, create an image of the card, once done, you can move the image to a blank card, Do not format new card when you first insert. Won't damage card, just a waste of time
    • davebtech
      • Apr 2015
      • 176
      • Hansen88
        • 1068
        The Target should be your blank card. It is just saying if anything is on that card it will be overwritten. Source should be the good card.
        • davebtech
          • Apr 2015
          • 176
          Thanks but I mean the initial copying of good sd to target....don’t you need to copy good one first in order to transfer?
          • Hansen88
            • 1068
            My laptop does not have a sd card slot so I bought two usb to sd adapters. So I plug both into my usb ports. I put the good sd card in one and the blank in the other. The usb drive with the good card I make the source and the drive with the blank the tatget. It is quicker that way because it eliminates a step and reads the good one and copys the blank at the same time.
              great way.. one Q.. (cuz I never did it)
              do you error check source drive first?
              • Hansen88
                • 1068
                I would say no. I am old school as far as computers, not sure how to error check. I use a sd card from a working machine. Have not run into any problems so far.
                • davebtech
                  • Apr 2015
                  • 176
                  Thank you!!!!!,finally got around to trying it, worked great Thanks!!!!!
