Sharp 5623N L4-1 error
  • dannys
    • Jun 2019
    • 12
    Hello,
    We got an Sharp 5623N that we change the dev unit, installet new one and pop up L4 -1 error in random order( after 5 copies ,10 or even 30 copies).
    Sim 25-1 motor runs fine , plugs fine.
    Any idea what we should check?
    Thanks in advance.
  • tmw
    • Dec 2013
    • 260
    Re: Sharp 5623N L4-1 error
    L4-01 says it's a main motor error. It may need a new main motor, or check the loads on any of the components that turn. There could be some binding that the machine isn't happy about.
    • Hansen88
      • 1085
      Maybe a cleaning blade flipped and is causing drag.
      • dannys
        • Jun 2019
        • 12
        Thank you for your time,
        I opened the fuser and found some plastics peaces inside , I checked the Drum unit also turns fine, developer to, problem still exist .I don't have motor or board to test.
        The odd thing is that the error cames first and after 2-3 sec the motor stops.
