SHARP Thread - Sweden
  • SharpSwe
    • Sep 2019
    • 11
    We're gonna compile a couple of issues we've had here in Sweden that might not be the most common problems. If you have any questions. Please take them through personal messages.
    Phoenix/Griffin-Serie (3050, 4070, 5070 etc.)
    Error: F2-64 - F2-67.
    Printer empties developer, shoots out toner cart and gives error code.
    If DV, DV-cart change doesn't fix the issue.
    Change: Photo Sensor [VHPLG2A13NL-1] & Middle Toner Hopper Unit [CBOX-0223FC31]
    Error: MFP Doesn't boot, LED Blinks, DF Scan doesn't work.
    Check: Paper clips have been an issue, falling down on the DSPF Control PWB when the paper clip hasn't been removed before scanning and causing a short circuit.
    Solution: Removing the paper clip might work, or else the Control PWB has to be changed.
    Error: C4-20
    If PTC-Unit doesn't fix the issue.
    Change: PTC Outer Holder [LHLDZ2540FCZ2]
    Error: Squeaking Noise
    Try: Lubricate 1st Drive Coupling on Belt & Cog Wheel inside MFP
    Error: MFP Keeps Rebooting, Doesn't Start.
    Try: Emergency Firmware Update.
    This thread will be updated regularly when more weird issues arise.
  • Jhonjon
    • Sep 2013
    • 208
    Re: SHARP Thread - Sweden
    Error: C4-20
    Thanks for sharing.
