MX5141N green screen on touch pad
  • harrythej
    • Apr 2019
    • 7
    hello,
    i was working on a MX5141N yesterday i changed out the DC unit and the machine powered up nicely but now the display is green in parts where it is supposed to be black. was wondering if anyone has a idea of what is going on and could use some help to correct it. thank you in advance.
  • tmw
    • Dec 2013
    • 260
    Re: MX5141N green screen on touch pad
    I've seen before if a dimm, ribbon cable or module unit isn't seated quite right, the display can look goofy.
    • harrythej
      • Apr 2019
      • 7
      i will definitely check he ribbon cable, also check the seating of the modules thank you.
      • harrythej
        • Apr 2019
        • 7
        checked all ribbon cables and modules. nothing seems to fix this issue. anyone else have any ideas?
        • bilyahn
          • Dec 2006
          • 1470
          Is it possible to put the old DCPS back in the machine? Would be interested in the result.
          Bil
