MX 4070N stripping black developer
  • driving lots of miles
    • Jun 2016
    • 398
    We have an MX 4070N stripping black developer. This is the third time in 6 weeks that we have replaced the black developer.
    I have checked that the toner is dumping into the developer unit (we are using sharp OEM toner), I have replaced the developer unit itself with a new one, Today I replaced the developer, Drum unit and waste. Contacts are clean. I am not getting any error codes, the firmware is updated
    with the latest.
    all the maintenance has been kept up to date. the copier is almost three years old in a clean enviorment, the customer copy count is 133,769 black and 195,638 color (329,407 total). The copy quality is great until the black developer starts depleting. Any ideas are appreciated
  • xring1958
    • 166
    Re: MX 4070N stripping black developer
    We have talked to Sharp several times about this. Their answer is that it drum wear that is making a short from charger to drum core and pulling Developer out of DV Unit at a slow rate but not enough to pop a code. All that said we have replaced Drum units and developer units just to cover our bases. You are probably getting a spiral weak area that some call barber poling or tiger striping.
    • NYPRNLA
      • Sep 2015
      • 21
      Sharp sells UKOG-0309FCZZ seal powder to prevent the ends of the drum from wearing out and causing dv pull. In class, the teacher highly recommended using it to prevent dv pull from occuring. I ordered some for all of our techs and our shop desk and it seems to work well. You place a small amount on the red felt seal at the ends of the drum unit before putting in a new drum.
      • paul.felton2
        • Feb 2019
        • 13
        Also worth checking the drum quenching lamp, its the led on the inside of rear frame as can become contaminated with toner, blocking light onto drum frame optical webb plate
        • xring1958
          • 166
          [QUOTE=NYPRNLA;819395]Sharp sells UKOG-0309FCZZ seal powder to prevent the ends of the drum from wearing out and causing dv pull. In class, the teacher highly recommended using it to prevent dv pull from occuring. I ordered some for all of our techs and our shop desk and it seems to work well. You place a small amount on the red felt seal at the ends of the drum unit before putting in a new drum.[/QUOTE
          Thanks I ordered some at your recommendation. I remember them mentioning it MX-7500 school but sometimes I take manufacturers advice with a grain of salt. I much prefer the reports of actual use by other techs.
            • Jun 2016
            • 398
            Untitled 3.jpgUpdate: it happened the first of the week again. We called the sharp Hotline and their only suggestion was that the toner was clumping and to replace the toner and developer and to clean the toner tube. we did and brought the old toner back and opened it up and found large hard clumps in the toner. I hope that it was just this one toner causing the issue. We only use genuine Sharp toners in all of our Sharp machines. We will wait a couple of weeks and see if this solves the issue.
            • xring1958
              • 166
              Originally posted by driving lots of miles
              [ATTACH=CONFIG]43715[/ATTACH]Update: it happened the first of the week again. We called the sharp Hotline and their only suggestion was that the toner was clumping and to replace the toner and developer and to clean the toner tube. we did and brought the old toner back and opened it up and found large hard clumps in the toner. I hope that it was just this one toner causing the issue. We only use genuine Sharp toners in all of our Sharp machines. We will wait a couple of weeks and see if this solves the issue.
              Was it hard like maybe it fused in a hot car? We have had partially fused toner with what we called rocks get into DV unit and block the doctor blade resulting in streaks on Mag roller where toner rock blocked the developer from getting on the Mag roller. Or was this actually causing to be pulled out of unit into waste toner container? After looking at picture it sur looks like it is just blocking doctor blade.
                • Jun 2016
                • 398
                No it was just blocking the doctor blade and then blocking the toner transport pipe which caused the low level of developer and toner in the developer unit. The toner had square type chunks in it, one of which measured 1/2 inch by 1/2 inch by 1/8 inch thick. it would break apart when you crushed it with pick.
                  clumping usually means it has been stored in too high of a heat environment or not shaken enough before installing... my 2cents
                  • Nachoman4life
                    • Oct 2007
                    • 212
                    One helpful hint, open the end of the the waste toner auger port of the drum, and vac it out during a pm. seen a few of them forming large toner clot buildups at the front frame side, that eventually end up in waste toner backups, hence broken augers, charge contamination, and eventual drum wear that causes dv pull. Was soposto be fixed with new waste boxes, but still seeing buildup and clotting at the waste exit port. PS Sharp has had an issue with edge of the drum wear for quite some time, vac or replace edge seals regularly.
                    Have been working on Sharps in KS for 15 yrs never seen toner clotting like that...
                    Where the heck is my spring hook?
                    • Nachoman4life
                      • Oct 2007
                      • 212
                      Agreed, had a Mxb42cl bleed out the rear frame side, down to the 1st transfer... Heat and storage...
                      • chubblies
                        • Jun 2011
                        • 154
                        The erase lamps at the rear of the machine contaminate really easily and will cause dev pull in no time. You cannot see them easily unless you go into sim 6 to turn them on, but they are tiny and it takes nothing to cover them up slightly which will then cause dev pull (we have had this happen).
                        The twisted drum augers is caused by the crappy waste shutter system not opening fully and it is always worth vac'ing the drum frames every visit to avoid them going. The M and C drums seem more prone to this.
                        • RascalMJ
                          • Mar 2009
                          • 174
                          This is very interesting, I am starting to see this more and more with M and C. Could you explain a little more what you are talking about with the Erase lamps and which SIM in 6 exactly. I just walked over to a similar system and saw a few choices. I just want to make sure I have this right.
                          Also, when you say vacuum the drum frames, what are you talking about specifically. Thanks for this!
                          • chubblies
                            • Jun 2011
                            • 154
                            Sorry, typo, sim 5 not 6. Specifically sim 5-04 to test the lamps. I think you just need to cheat the door but you will see them glow orange.
                            I always vacuum the part that enters the waste box, as the mechanism is a bit rubbish. It basically has a small plastic pin on the waste bottle that pushes a recessed cap in the drum frame to open the shutter. This mechanism is what I vacuum.
                            There are all reports of the front door switch actuator breaking in half, and the debris from it jams the waste bottle drive gearing, so this is also worth checking, though I have never had it.
                            In my opinion the magenta and cyan toner is more dusty than the yellow and black, and this dusts up the erase lamps moreso that the yellow and black, which in turn causes the toner to pull excessively whilst the drum is doing a non-copy rotation, (and can cause the waste system to block up) but as well this also drags out the dev over time.
                            They run dirty so a vacuum is necessary every visit in my opinion.
                            • RascalMJ
                              • Mar 2009
                              • 174
                              Thank you so much.... We have been struggling with a few of these models. First with motors and now dv dumps... Etc. Ugh
