MX-B402SC throwing L6-04 code
  • guitar9199
    • Sep 2016
    • 1100
    Hey Campers,
    Need a bit of an assist. I'm having trouble locating the part numbers for the 1TUD_K and 1TUD_CL sensors. The Sharp parts manuals aren't laid out in a very "user-friendly" way.
    Any assistance will be greatly appreciated!!
    Any personal insults for my inability to locate 2 part numbers will be accepted gracefully... but I will make a note of it. (I'm part Italian after all... it's what we do!)
  • spanky
    • Sep 2012
    • 468
    Re: MX-B402SC throwing L6-04 code
    Did you mean L4-06?
    If so
    Replace VHPLG248NL1-1 right side sensor VHPGP1S73P+-18 left side sensor
    • guitar9199
      • Sep 2016
      • 1100
      Originally posted by spanky
      Did you mean L4-06?
      If so
      Late Afternoon Dyslexia.... you are correct!
      • copiertec
        • Jan 2016
        • 2206
        Re: MX-B402SC throwing L4-06 code
        [QUOTE=guitar9199;821025]Hey Campers,
        [/QU
        It's the sensor in the back of the copier when you remove the belt, clean it. Also, make sure when you remove the belt unit, the actuator that is attached to it, is working properly.
