Service mode back door
  • JPazy
    • Jul 2019
    • 30
    Does anyone know a way to enter service mode on Sharp MX 4140 when the Home key isn't responding?
  • miller01123@gmail.com
    • Jun 2019
    • 55
    Re: Service mode back door
    You will have to figure out why the home key is not working.
    • mansart
      • 854
      Remote Op.....
      Browse to IP of printer>>Go to Operation Settings>>>>Scroll 2/3 rds of the way down in main window, Look for Remote Operation
      Go to Operation from Specified PC section..... change to Allow ..... in box below put in IP of PC you will be remoting from.
      And Submit.....
      Download and run TigerVNC viewer.....enter IP of copier....click connect.....in password field use admin password for copier.... default admin
      At this point you should program should load a remote instance of the operator panel. You can get to SIM's in same manner as physical panel.
      TIGERVNC VIEWER
      • Jamiesdad2
        • May 2009
        • 29
        Use the keyboard and hit F-11 twice
        • JPazy
          • Jul 2019
          • 30
          Thank you for the information. The web browser and TigerVNC Viewer worked great to allow access to service mode while waiting for the new Home Key to arrive.
