Mx m264 8 1/2 x 5 1/2 screen notice
  • mlbcopiers
    • Oct 2007
    • 34
    My customer keep getting an error on the copier when they are printing from their computer to change the paper size to 8 1/2 X 5 1/2. The cassettes are letter and legal. They do not want to copy on statement size. The request to the printer/copier is an email or a printed file on their computer. the computer print specs are for letter size.
    This just started a couple of days ago. They have to reset the copier to clear the message.
    Has anyone had this issue. I am baffled.
    Thank you,
    Mitch
  • copiertec
    • Jan 2016
    • 2186
    Re: Mx m264 8 1/2 x 5 1/2 screen notice
    Chances are, if it is an email, it's the pdf that is causing the issue because it is calling for 8.5 x 5.5 when sent to the copier. I would suggest using Foxit PDF converter on the offending PC and see if that resolves the issue. This is a common problem with emails.
      +1 or if a Word or similar type files.. check file properties to make sure it isn't formatted to 8.5 by XXX.
