MX-4070N slow out of trays 1-4 only
  • articcat182
    • Nov 2014
    • 24
    I have an MX-4070N, been in the field almost 3 years. Copying or printing plain paper out of trays 1-4 (DE28 btw) picks up paper, and doesn't feed another sheet until the first copy/print is out of the finisher. It has an LCC tray, plain paper feeds normally out of the LCC, and the bypass tray. We have done the usual - Updated firmware,emergency firmware, DE28 PWB, replaced PCU, msata, HDD, MFP/SCN PWB, reset all settings back to factory, even went as far as copying a 4070N in 56-2 and putting that information into the copier ... Still has slow feeding out of the trays. Sharp is clueless on this one too. Anybody have any ideas?
  • mansart
    • 855
    Re: MX-4070N slow out of trays 1-4 only
    As problems go, sounds as if you have a good one.....bear with me here, I'm just throwing out thoughts.....
    How does it behave if you do a multi-page internal print, like the web setting list?
    Disconnect all accessories including Doc Feed, does it behave the same from tray 1? I bet if you solve tray one you solve them all....
    Does this machine have a security kit?
    How does it behave when doing a 2-2 run??
    • OlliK1969
      • Nov 2016
      • 312
      Hi
      JobLog more then 60k??
      Clear it and reboot
      • repn1999
        • May 2010
        • 310
        check 50-10 adjustments for the trays. are the trays set to different paper types.
        • articcat182
          • Nov 2014
          • 24
          Sorry been a busy bee.. All internal prints, one page at a time, does not matter what drawer. Disconnected all accessories, still slow prints, no dsk, have not tried a 2-2, will update after I try that
          • articcat182
            • Nov 2014
            • 24
            UPDATE
            Ran end of lease on machine, reset everything back to factory, unplugged all accessories (dspf, de28, fax) still does not make a difference in how the machine runs.
            • mansart
              • 855
              How does it act in SIM 7, misfeed disable?
              LCT and bypass work.....
              Paper trays exihibit the slow feed problem......
              What is different between the paper path of the two?
              1. the angle that the paper enters
              2. by pass path does not use C1PFD
              From the manual I cannot determine where the signal comes from to tell the machine to feed the "NEXT" sheet of paper. Bypass feed path does not use C1PFD. LCC paper path does drive paper by C1PFD, however the paper is hitting this actuator at a completely different angle. And LCC being an accesory may not even use this switch for timing.
              C1PFD would be my next step. extra wrap on actuator spring has never hurt...
              • articcat182
                • Nov 2014
                • 24
                First of all - Thanks for helping me with this issue!!
                I first tested C1PFD, it tested fine, and then I wrapped the spring around the shaft one more time, just for kicks.
                Ran copies, no change it spits out around 5 copies a min
                Then I tested the Misfeed detect disable 5 copies each time - Heeeeeeere's where it get's interesting...
                The paper feeds the first sheet at the speed it should - IT IS BLANK!
                Then the next sheet fed out ontop of the sheet behind it, print is scattered all over the place, BUT it did print out faster now.
                From what I tested for bypass and LCC, they do not use C1PFD
                • mansart
                  • 855
                  Misfeed detect disable can be tricky, because the signal from the sensors is ignored so timing can be off. So don't be so concerned with how copies look with misfeed detect disabled.
                  Essentially misfeed disable is good for isolating a problem. If the paper passes with misfeed detect disabled you know mechanically the machine works, so you know you have a sensor/electrical problem. If paper does not pass with misfeed disable you know you have a mechanical problem.
                  In your case..... with misfeed detect disabled...."The paper feeds the first sheet at the speed it should - IT IS BLANK!
                  Then the next sheet fed out ontop of the sheet behind it, print is scattered all over the place, BUT it did print out faster now."
                  Because the machine prints faster with sensor signals being ignored.....this would point in the direction of electrical........sensors, boards, harness etc.......
                  Everything about this screams PCU board, as it's handles component on/off and timing.
                  If able print a 22-6 report and a 23-2 "ALL" scan and post and/or compare to a working machine....not sure what to tell you to look for other than any "GLARING DIFFERENCES"
                  • mansart
                    • 855
                    Is this machine connected to any type of external accounting device or vend system?
                    • articcat182
                      • Nov 2014
                      • 24
                      Multi-page internal print, just one page at a time, does not feed another page until the print is in the drawer
                      No external accounting, or 3rd party accounting systems
                      PCU has been replaced before this post was started
                      UPDATE!
                      I have a 4070 going back to leasing company, so I swapped paper feed 1 units, no change. Then I swapped Paper Feed Motor Units, all problems are taken care of. I think that the motor signal was the issue, and swapping out the units was my only option, as the lease return is going back right away, sooo... unfortunately, no time to play with it, to determine which component was the root of the problem.
                      But, Thanks for all the help!! This sure was a weird one
