Sharp MX-M904 Image Shift
  • acribari
    • Aug 2015
    • 45
    #16
    Re: Sharp MX-M904 Image Shift
    No I have not tried sim 50-10. The high cap trays are centered so will this mess them up if I use sim 50 -10?
    I can go back and give it a try.
    They are running 80 pound card 12X18 and it does see the size on the display panel. I can select bypass tray and it shows 12X18 heavy stock.
    I can feed out of tray 5 and 6 and it is centered. But after a few sheets it jams from those trays. So I am hoping after I get the bypass centered it will not jam feeding from that unit.
    I will try sim 50-10 and see if it works out.
    Thanks for the tip. I am desperate at this point. Lol... Thank you!
    • spanky
      • Sep 2012
      • 468
      #17
      In sim 50-10 you can choose which tray (including bypass tray) you want to adjust.
      All other trays will not be affected.
      • acribari
        • Aug 2015
        • 45
        #18
        Thank you very much for the info. I went to the account today and ran 50-10 on HCT Bypass tray and the data setting was on 48. I had to move it to 95 and now its perfectly centered on 12 X 18 and all other paper sizes.
        Thanks again. You saved me. lol.... I really apricate your advice.
        For some reason they don't have the tray adjustment listed when you install the bypass unit. It just tells you to install it and how. I could not find a place in the service manual for this adjustment until I asked you on this forum. Seems odd that they would not run you through this on the installation.
        Thank You !!!!!!
        • spanky
          • Sep 2012
          • 468
          #19
          The adjustment is covered during training.
          • acribari
            • Aug 2015
            • 45
            #20
            Ah, that makes sense. I did not have any formal training on this model. Just have the service documentation. Thanks for all the help.
