MX 5111 losing black print.
  • Hansen88
    • 1046
    I have attatched samples of internal black prints to show problem. Color seems fine but black print areas will fade out. It seems to get worse the more copies you run.I have replaced the black drum and developer along with charge kit. They were comming close to end of life. I also replaced the entire transfer -pri unit. seeing if anybody has any suggestions. Thanks
