MX-3640 unable to access network settings
  • copiertec
    • Jan 2016
    • 2188
    I have a MX-3640n that I am unable to access the network settings to change ip and dns settings. At first I was unable to access admin password because it was changed by the former IT person, so I set it back to default admin password. But, at the homepage in settings it only shows the top page icon and system settings icon and I have no access to network settings at all. I can't even access the web page because the IT person changed it as well. Any suggestions?
    The copier has no security kit installed
    After restoring default password
    I restored the factory defaults
    Formatted HDD
    Updated firmware to latest
    Updated e-manual
  • JLSam
    • Jun 2015
    • 605
    Re: MX-3640 unable to access network settings
    Do you have the option to perform the End Of Lease feature?
    Sent from my GM1917 using Tapatalk
    • copiertec
      • Jan 2016
      • 2188
      Yes, I do. I could try that.
      • JLSam
        • Jun 2015
        • 605
        That will take care of it. Perform the feature, step outside, go for a nice walk, think about the meaning of life, buy a burger with fries and a drink. Finish your extended lunch, and come back to the office. You will probably need to wait a little more for the end of lease to finish, but at least it will take care of your issue.
        Good luck!
        • copiertec
          • Jan 2016
          • 2188
          Thank you, Sam, I will let yo know how it turns out.
          • copiertec
            • Jan 2016
            • 2188
            20191106_092154.jpg No go Sam, I do not have access to security settings. This is all I get when I go into the settings page, not sure what to do next.
            • OlliK1969
              • Nov 2016
              • 310
              Hi
              Are you in admin modus in?
              Can you go in SIM 67 ??
              • copiertec
                • Jan 2016
                • 2188
                Originally posted by OlliK1969
                Hi
                yes, I am able to get into all sim modes as well as admin mode. I did perform a 67-17, but to no avail.
                • OlliK1969
                  • Nov 2016
                  • 310
                  • brokey
                    • Oct 2011
                    • 21
                    Log into the webpage as admin, select settings and there should be a check box to show the various functions.
                    • JLSam
                      • Jun 2015
                      • 605
                      Umm... what happens when you click administrator login on the top right hand corner of your image?
                      • spanky
                        • Sep 2012
                        • 468
                        access the service web page by entering the IP address/service_login.html
                        The password is service
                        Go to administration settings
                        where it says item to be displayed click on the execute button that says all
                        • mansart
                          • 852
                          As an example.... your machine IP is 192.168.0.212
                          Browse to http://192.168.0.212/service_login.html
                          password = service
                          Scroll to bottom of page and click "Administration Settings"
                          Click "Execute" button by "All"
                          • mansart
                            • 852
                            Spanky beat me to the punch....
                            • copiertec
                              • Jan 2016
                              • 2188
                              Thanks guys, I will try logging in on the webpage with the ip address given to the mfp. The client is on a 192.168.0.1, apparently the IT person changed the ip to 192.168.1.1. I am on my way back to the client, I will keep you posted.
