Sharp Copier Sims
  • leew
    • Jun 2013
    • 10
    [Misc] Sharp Copier Sims
    Just looking at all the Sharp simulations and I use a lot of them for troubleshooting problems like sim 1-2, 2-2, 3-2, 7-1, along with the ones that clear the codes. Also I use 22-40 and 41 for the list of codes and errors. So what codes do you seem to use the most? Just a question for the input of others.
  • ZOOTECH
    Senior member of CRS
    • 3381
    Re: Sharp Copier Sims
    Refer to the installation manual during setup, and after service/pm. I've been retired 3.5 years, but I remember that adjusting print/copy position, you would use the sims in the 50-sub range. For print/copy quality, use the 46-sub range.
    • copiertec
      • Jan 2016
      • 2172
      Most often used 22-6, 24-1 and 64-1,5 if no calibration needed or error codes need to be reset.
