Password change in machine but not web page(?)
  • tmw
    • Dec 2013
    • 259
    Went to restore the default password changed by a disgruntled employee. Did the dip switch method and it changed back no problem. Could access all settings from the control panel on the machine. I went to show how to get to the web page to do settings from there. When I typed "admin" to get to those particular settings, it said it was incorrect. There were no other tabs to choose like system administrator, or user. Just the one. Do I have to change the password somehow for the web page as well somewhere ? I've had to reset passwords before and haven't seen this happen yet. If anyone has come across this anomaly, I would appreciate your insight on what might be happening. Thank you
  • copiertec
    • Jan 2016
    • 2206
    Re: Password change in machine but not web page(?)
    MX-3640 unable to access network settings Does this help?
    • bilyahn
      • Dec 2006
      • 1470
      When you use the dip switch it should of brought up 2 options. you need to reset both. One is for the admin password and the other one is for the web password.
      Good luck
      Bil
      • NYPRNLA
        • Sep 2015
        • 21
        Aside from the suggestions above make sure you only use Internet Explorer for web page access. Chrome, Edge and Firefox will sometimes add a space in the password field and cause an incorrect password error.
        • tmw
          • Dec 2013
          • 259
          Thank you for all your suggestions. I may or may not have to go back there, but it's good to know now if I see it again.
