sharp 5618
  • atefcoperson
    • Dec 2019
    • 3
    sharp 5618
    Sharp ar 5618 error code f2 64
    Hello technet friends,
    have sharp photocopier giving error code f2 any help on how to clear it display 64
    thanks.
    Re: sharp 5618
    Originally posted by atefcoperson
    Sharp ar 5618 error code f2 64 Hello technet friends,
    have sharp photocopier giving error code f2 any help on how to clear it display 64 Thanks.
    what was it doing before it kicked the error?
    what did you do to try and correct?
    you gave us NO information besides the codes..
    it this how you treat the car techs when You take it in for service?
    • doyvid
      • Aug 2019
      • 56
      Re: sharp 5618
      Check the white "coupler" gear on the back of the drum unit. The waste auger in the drum unit seizes and breaks the coupler. If that's broken, take apart the drum unit and clean the waste auger until it spins with little resistance. The gear is easy to replace, no tools necessary.
      • atefcoperson
        • Dec 2019
        • 3
        Re: sharp 5618
        [/INDENT][/COLOR]
        The ink has been completely changed and it is printed first paper and then show the code then stop
        Strangely they print the first paper only and then stop
        • atefcoperson
          • Dec 2019
          • 3
          Re: sharp 5618
          it doesn't work
          • dsmith46
            • Oct 2016
            • 81
            Re: sharp 5618
            "The ink"??? Are you a technician or an end user? You should probably leave the repairs up to someone who knows what they are doing.
            • doyvid
              • Aug 2019
              • 56
              Re: sharp 5618
              Make sure you're using genuine Sharp toner and developer. There's no way to just reset this code.
