Disable front USB on MX-5071
  • mttech
    • Mar 2014
    • 127
    We had a customer request to have the front USB disabled on this machine for security purposes (the machine is located at a bank) but I can't find anything in the service manual about it. The only mention of enable/disable of USB that I could find, and that the Sharp Hotline also suggested, was SIM 26-50 which is for enabling the machine to be used as a USB printer. Is there a soft switch or dip switch, or is the only option to unplug the USB PBW?
  • kdr363
    • Apr 2019
    • 63
    Re: Disable front USB on MX-5071
    System settings/common settings/device control/enable disable. Disable "scan to usb" and disable "print from usb" (2 separate check boxes).
    • tsbservice
      Field tech
      • 8007
      Or unplug it from the board...just kidding
      I think every brand that can be disabled from admin menu.
