Sharp MX-C311 Image Send Network Error CE-00
  • InsaneOil
    • Dec 2019
    • 2
    I put a pre-2011 Sharp MX-C311 back into service recently. I am attempting to set up Image Send to an Office 365 E-mail.
    After inputting DNS and SMTP Settings the connection to SMTP server test succeeded. I also changed SSL Level of Encryption to "Middle" to emulate TLS.
    After running a test document I get "Network error. (CE-00) Consult your network administrator."
    I went into the the router and have tried both DHCP and Reserved IP and the result is the same (CE-00).
    Thoughts? Or is the machine just to old to have these capabilities with the current technology?
    Any information would be greatly appreciated.
    Thanks.
  • copiertec
    • Jan 2016
    • 2206
    Re: Sharp MX-C311 Image Send Network Error CE-00
    I am almost certain the MX-C311 does not support TLS 1.2 or higher. I know Sharp put out a firmware update for that on the MX-C312 model, in order for it to support TLS 1.2, but not one for the MX-C311 model. Same machine really just different firmware.
    • spanky
      • Sep 2012
      • 468
      There is firmware for this machine that supports TLS1.2
      Download from Sharps service website.
      • copiertec
        • Jan 2016
        • 2206
        Spanky is correct, they do have firmware for TLS 1.2 for the MX-C311.
        • InsaneOil
          • Dec 2019
          • 2
          Thank you, I greatly appreciate the all the information. Unfortunately, I do not have access to the Sharp Service Website but it is good to know that there is a firmware upgrade out there.
          • leong.supertroni
            • Aug 2015
            • 13
            Under "Reply email address" , u need to add
            <XXXXXX@domain.com>
            Sent from my MI MAX 2 using Tapatalk
