Sharp MX 4141
  • Reed
    • Feb 2011
    • 261
    Sharp MX 4141
    I went out on a Sharp MX 4141 yesterday. When you turn it on the machine comes to ready and the control panel is responsive. Then machine is not connectected to a network. If I try to make a copy the machine freezes up and becomes unresponsive. I tried to perform a 66-10 image clear but nothing seems to happen. After rebooting several times I was able to get the machine to make copies and internal prints but when I power cycled the machine again. It had the same issues Any Ideas. Thanks in advance
  • EasyRider
    • Jan 2015
    • 88
    Re: Sharp MX 4141
    Cheap and (somewhat) easy is firmware first and if that doesn't help, re-do or replace the sd card.
    Good luck!
    • copiertec
      • Jan 2016
      • 2222
      Re: Sharp MX 4141
      Ditto, on what Easyrider said.
      • repn1999
        • May 2010
        • 310
        Re: Sharp MX 4141
        first i would say sd card....if not that maybe replace the entire operation panel. I know this sounds wierd.....but I have seen these act where the screen was frozen but it would still print and the webpage still would work. it was 50/50 in the senario as to which one it was. also....check the wall voltage. power cannot drop below 110v EVER....and ground to neutral must be less than 2v.
        • youfster
          • Dec 2021
          • 3
          Re: Sharp MX 4141
          Hey did you manage to sort this out? Seeking firmware for the same model.
          • MattL
            • Apr 2012
            • 97
            Re: Sharp MX 4141
            Try clearing the job log as well as the above.
