Power Requirements
  • oeshuron
    • May 2008
    • 259
    Power Requirements
    Anyone have anything from Sharp stating an MX-5070N should be on its own dedicated circuit?
    Re: Power Requirements
    that is something that every one of the 20 brands I work on state in the manuals
    • oeshuron
      • May 2008
      • 259
      I looked in the installation manual and service manual. Can you tell me the page it states dedicated circuit as I might be glossing it over? I understand they should be on one, just looking for documentation stating such for these machines we can provide the customer.
        service manual... POWER requirements
        even better call sharp tech support have them send you statement required
        with newer units the power has a tighter tolerance values
          • 30552
          More useless help from Phil
          Most new machine don't required it. Just put a power filter on it. Like esp
          • oeshuron
            • May 2008
            • 259
            Just asking if anyone else had a bulletin or tech tip, similar to the ones available from 2011/2014 for older models, for the newest machines. Better than bothering Sharp with it if there is one which has been released and I can't find it. I am going to send customer the older bulletins and see what happens.
            • mansart
              • 855
              ExtractPage1.pdf
              • oeshuron
                • May 2008
                • 259
                There is an ESP Next Gen PCS 20 Amp on it. There is also a dorm sized refrigerator, fellowes commercial shredder, and coffee maker which are plugged into what a appears to be a double gang box. Have sent an email to see if they can check on whether it is two different circuits or not.
                • oeshuron
                  • May 2008
                  • 259
                  Originally posted by mansart
                  [ATTACH]44772[/ATTACH]
                  Well holy crap. What shall I search to find that 13 page pamphlet?
                  Or is that a dealer only (non ccr) item?
                    • 30552
                    Looks like it's should be on its own power line. What kind of problem you got? Move the shredder if possible.
                    • oeshuron
                      • May 2008
                      • 259
                      Just a large number of calls and service codes. We're requesting a dedicated circuit or a moving of the machine. The area its in is small plus its a breakroom type area.
                        breakroom w/ fridge... coffee pot... microwave... maybe with soda machine.. small toaster oven/toaster.
                        all those things have a high draw on the circuit .. knowing how wall circuits are laid out .. they might have one or two runs in the room.
                        i bet if you put an enVision recorder on it you would notice high draws @ 0800-0900 1130-1230/1300 normally the people are running the above appliances in the break room ..
                        I had Oki MFP's in a manufacturing area (electronics) every time the 3,000# air compressors kick in, one of the 3 assembly lines power would dip and cause the oki's to lose their frigging minds.
                        put the enVision on each line and a monitor @ compressors .. sure enough the dip was JUST small enough to affect the MFP's but not noticeable in light or other power at the stations.
                        1 dedicated line split to power the 3 mfp's... viola no more power issues.
                        their industrial engineer like the enVision he bought one for the shop there. It was about $250usd if I remember correctly.
                        Mine was really great at pointing out many problems in other buildings
                        Can be found here: enVision IC 120 - 208V Predictive Analysis Software
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          I totally agree.
                          Not only can problems be caused by the voltage going low, spikes can be introduced by anything that cycles, such as mentioned.
                          Those spikes can only be a millisecond or two, but can cause havoc. The spikes are actually worse when the device cycles off, and not on, similar to an ignition coil on an engine, when the EMF field collapses.
                          Not all models feel it equally. Two similar yet different models from the same manufacturer may feel it differently.
                          • davel
                            • Oct 2011
                            • 1108
                            Please don't let your political differences bring bitching to the technical forums.
                            • Nachoman4life
                              • Oct 2007
                              • 212
                              Had a Sharp MX6240 running on a 120v20a circuit with very few problems , given it was a basic box, no lcc, or fin... just a H4 code every couple of months, delivery guys "pig tailed" it, actually was a very good machine, when I last stopped servicing it 3 yrs ago, it was still a good machine.. 220v machine running fine on 110v.... long warmups was the symptom..
                              Where the heck is my spring hook?
