Interesting find: Msata cards
  • bigdaddyooo
    • Dec 2014
    • 211
    Had a 3550 throwing E7-80's and 90's. I swapped the Msata card out with one from a functioning machine. Now that machine is running great and the problem is now with my shop copier who's Msata I swapped it with. I updated the firmware via 49-1....E7-80's and 90's. SOOOOOO, I did a CN update and problem is now eradicated. So, it seems when you have a suspect Msata card, update it by switching the update switch on the MFP pwb and do it that way. No errors on this machine since doing that. Just an observation
    Are you the police? "No ma'am, were musicians"
  • bigdaddyooo
    • Dec 2014
    • 211
    UPDATE Re: Interesting find: Msata cards
    Machine has been running since yesterday and has NOT had an error. I had 2 errors before I CN updated the firmware.
    • Nachoman4life
      • Oct 2007
      • 212
      have not tried to overwrite a failed msata, but will spinwrite a few when I have a chance, to see if its a hard fault, or just a read error...should we start a new thread.... Are the sharp msata cards rewritable, after failure.....?
      Where the heck is my spring hook?
      • bigdaddyooo
        • Dec 2014
        • 211
        Been 3 days now and NO errors. I say it's a go to CN update a bad Msata.
        • copiertec
          • Jan 2016
          • 2192
          Re: UPDATE Re: Interesting find: Msata cards
          What do you mean by a CN update?
          • bigdaddyooo
            • Dec 2014
            • 211
            On the MFC PWB there's a switch up on the top. It says update turn that on then power up the machine. You'll see six blocks on the control panel. Make sure you have USB stick in. You tell it to update the firmware and then you tell it which file to upload. That's a CN update.
            • bilyahn
              • Dec 2006
              • 1470
              Originally posted by Nachoman4life
              have not tried to overwrite a failed msata, but will spinwrite a few when I have a chance, to see if its a hard fault, or just a read error...should we start a new thread.... Are the sharp msata cards re writable, after failure.....?
              I have had mixed results when re-writing failed mSATA. Probably a 75% success rate so we are happy but if the CN update will work on a failed card that would be fantastic.
              Have a great weekend.
              Bil
              • bigdaddyooo
                • Dec 2014
                • 211
                Bil
                Like I said Bill, it was just an observation. That was the first time. I tried it on a card that was giving me E7 80s and 90s. It is been 3 days plus and the machine has not had an ever since that so it seems to be successful. Again, it's just an observation. You also have a great weekend.
                • JLSam
                  • Jun 2015
                  • 605
                  I've tried that emergency firmware update method before on a 3570 to no avail. To he fair though, the issue wound up being the board, not the mSata.
                  Sent from my GM1917 using Tapatalk
                  • bigdaddyooo
                    • Dec 2014
                    • 211
                    Re: Interesting find: Msata cards UPDATE
                    All 4 machines are 60 days in to a CN update..Not 1 problem. 100% here.
                    • repn1999
                      • May 2010
                      • 310
                      I would like to point out something most have overlooked in this discussion....Machine specific meta data is stored on the msata card...and sd card on the older models. I do realize that some have swapped the msata cards and they seem to work ok...however sometimes they dont...and they end up causing us technicians problems that cannot be fixed easily. ie airprint wont work and serial number for airprint is missing or doesnt match serial from mfp/pcu or product key will not install, etc. What I did is bought a new MSATA for each machine model series and made an image of it prior to putting it in a machine and initializing it. New cards from sharp contain no meta or serial data and are safe to image. you can use a standard samsung 32gb as a replacement to write images on all day long and they will work many times longer and faster than the ones supplied by sharp.
                      • bigdaddyooo
                        • Dec 2014
                        • 211
                        [QUOTE=repn1999;1434627]I would like to point out something most have overlooked in this discussion....Machine specific meta data is stored on the msata card...and sd card on the older models. I do realize that some have swapped the msata cards and they seem to work ok...however sometimes they dont...and they end up causing us technicians problems that cannot be fixed easily. ie airprint wont work and serial number for airprint is missing or doesnt match serial from mfp/pcu or product key will not install, etc. What I did is bought a new MSATA for each machine model series and made an image of it prior to putting it in a machine and initializing it. New cards from sharp contain no meta or serial data and are safe to image. you can use a standard samsung 32gb as a replacement to write images on all day long and they will work many times longer and faster than the ones supplied by sharp.[/QUOT
                        Why would that be an.issue. We are NOT replacing the card, we are doing a CN update which effects nothing as to which you're talking about. We do this so we do NOT have to replace it.
                        • repn1999
                          • May 2010
                          • 310
                          [QUOTE=bigdaddyooo;1435100]
                          First I was addressing the comment someone made about swapping msata cards from another machine. Second....the reason you are having to CN update the cards is because they ARE failing. Clearly you understanding behind the issue is lacking. So solid state drives, and all flash memory have a finite number of times they can be written to before the cells or blocks within the chips start to fail or go corrupt. MSata ssd drives were chosen to replace sd cards due to the much higher endurance of NAND flash vs the sd card, along with the fact that they have algorithms built in ( TRIM) to manage block wear and reads and writes to the drive. HOWEVER, when the first Phoenix and Griffin machines came out, along with some of the others, the TRIM feature set was not enabled. It was not finally enabled until 4.0 firmware on the Phoenix and there is a tech bulletin backing this up. Without TRIM enabled the drives basically were running defrag constantly because a solid state is programmed to fill each memory block fully and to keep all parts of that data file together much like on your computer in defrag. So without TRIM the drives wear out very quickly and fail. Again this is documented in a tech bulletin along regarding E7 codes and no boot I believe. I can find the number if you are interested. SO.....CN update will temporarily get the machine back up just like you could do with SD cards, sometimes....but it is not a permanent solution. You can check the label on the mSata and if the sticker is less than 4.0 figure its probably gonna fail soon. If it is newer, your mileage may vary. I prefer to fix the issue the first time and not have to go back. Im responsible for over 750 machines in my territory and if I fixed my machines like some of you I would have tons of callbacks, pissed customers and more headaches than I care to deal with.
                          • bigdaddyooo
                            • Dec 2014
                            • 211
                            [QUOTE=repn1999;1435335]
                            Well thank you sir. I stand corrected. I have no problem with admitting that I'm wrong but like I said its 60 days in and no problems. I did NOT check the version on the chip so hopefully things will continue to work well.
                            • copiertec
                              • Jan 2016
                              • 2192
                              [QUOTE=bigdaddyooo;1442726]
                              I appreciate you sharing your discovery with the rest of us.
