Sharp MX2614
  • Kenny
    • Jun 2009
    • 508
    Sharp MX2614
    Hi guys,
    I'm currently working on a Sharp MX-2614 which has a lamp issue.
    The lamp is trying to drive but it 'jutters' and it doesn't illuminate, it moves an inch,stops then moves an inch again all across the flat bed in till i turn the machine off.
    i have replaced the scanner board, motor that drives the scanner cables and the lamp itself but no avail.
    does anyone have any ideas as to why this is happening?
  • bilyahn
    • Dec 2006
    • 1462
    Re: Sharp MX2614
    Originally posted by Kenny
    Hi guys,
    You didn't mention if you replaced the white poly rollers that the scanner wire runs through. Have had those do the same thing when the bearing goes bad. Does it move freely by hand?
    Good luck.
    Bil
    • Prints Charming
      • Aug 2019
      • 189
      Re: Sharp MX2614
      Did you replace the scanner lamp driver board/inverter board, which sits underneath the lamp? This powers the lamp. Check it if the lamp doesn't light up in sim test.
      The lamp must initialise first, reading the white reference strip under the main glass. Check the scanner lamp home position sensor in sim 1 when the lamp unit is moved by hand.
      When the machine boots, does the lamp unit move across to the left side of scanner without any L1 or L3 codes? Put the lamp over to the right side, then boot up to check scanner initialisation. If that works, but you have no lamp light, I'd be checking the driver/inverter board, possibly DC power supply but unlikely.
      • Kenny
        • Jun 2009
        • 508
        Re: Sharp MX2614
        Yes I have replaced that board, I forgot to mention the screen does not boot up when I turn the machine on so I can not see if there is any codes.
        • Kenny
          • Jun 2009
          • 508
          Re: Sharp MX2614
          Good luck.
          Bil
          Yes its moves freely by hand, it 'jutters' when I turn the machine on. Spoken to another Tech, he said it could be anything power related as the machines control panel not booting up.
          • Prints Charming
            • Aug 2019
            • 189
            Re: Sharp MX2614
            New info definitely suggests the problem is the DC power supply.
            No display, incorrect scanner boot up sequence. Both controlled by the Scanner board (which you've replaced), but sounds like insufficient power. Easy to check power input connectors from DC on that board.
