sharp desk mx-de14
  • clark
    • Sep 2016
    • 109
    [Jamming] sharp desk mx-de14
    Just got machine in today. tray 2 thru 4 jams every time. Removed back panel and it has a flashing red led light. Does that mean it notice that there a problem Tested sensor from the control panel and no luck. Checked connectors and all good there. machine say that its there. Any help would be nice. Thanks
  • mansart
    • 852
    Re: sharp desk mx-de14
    I'm assuming an MXB355/455 type machine.....
    Machine feeds fine from bypass and tray 1
    When the jam occurs is it same place everytime?
    Is there any noticible damage to lead edge?
    SIM 7 misfeed disable......will it pass paper from CS14?
    If it will -pass paper with misfeed detect disabled you are looking at a sensor/signal trouble,
    If it won't pass paper you are looking at mechanical.
    • clark
      • Sep 2016
      • 109
      Its a sharp mx2615n copier.Thanks
      • mansart
        • 852
        Oh ok sorry......same basic theory.....
        What is the jam code that results?
        Will it pass paper with SIM 7 Misfeed detect disabled?
        • clark
          • Sep 2016
          • 109
          with the misfeed turn off it will pass paper from the tray.
          • mansart
            • 852
            So looking like sensor issue.....
            Run a 22-6 and what are the most recent Jam codes?
            • clark
              • Sep 2016
              • 109
              alot of tray 3. and Dpfd1-n4 not sure of that one
              • mansart
                • 852
                post a copy of the 22-6
                page 1
                • spanky
                  • Sep 2012
                  • 468
                  D1PPD not reached.
                  See attached diagram.
                  • clark
                    • Sep 2016
                    • 109
                    Thanks for all the help. it turn out to be 2 sensors bad. replaced and ll is running. Strange machine on has 25k on it.
