AR 5120 error
  • Manoj ambatt
    • Oct 2019
    • 25
    AR 5120 error
    Gd morning every body
    I have an error f2 02 error on ar 5120 copier can anybody help me please
  • bilyahn
    • Dec 2006
    • 1470
    Re: AR 5120 error
    Toner error. Are you using OEM toner? Take toner out shake it and put back in, cycle the power and error should go away. If not replace the toner cartridge. You can take the cartridge out and look in the machine to make sure the plastic gear that drives the toner as not fallen off. If it is more involved than this I would recommend a tech take a look at it
    Good luck.
    Bil
