MX-3570 Printing Bad Image
  • Dwylie
    • Mar 2020
    • 7
    [Misc] MX-3570 Printing Bad Image
    I have this MX-3570 that has been in the field for almost 2 years and it started printing, copying and internal prints as just black lines. I have attached an image so you guys can see exactly what it looks like. Thanks in advanced for the help.
  • spanky
    • Sep 2012
    • 468
    Re: MX-3570 Printing Bad Image
    LSU
    • ZOOTECH
      Senior member of CRS
      • 3375
      I've had corrosion build up on LSU connections; and with a little contact spray, and cleaning - problem fixed.
      • Dwylie
        • Mar 2020
        • 7
        Thanks guys will check it out.
        • Dwylie
          • Mar 2020
          • 7
          ok so I forgot to try sim 64-1. I just tried it and number 1,2,7,11,19 and 22 came out fine. Which makes me think the LSU and memory is fine on the machine. Any ideas?
          • mansart
            • 852
            See this post by Prints Charming
            Bottom paragraph in post
            this may help isolate problem
            • Prints Charming
              • Aug 2019
              • 189
              Exactly Michael!
              64-01 tests are on the LSU controller, so if these appear OK, your LSU is going to be OK.
              You need to test 64-05 which is the PCL test prints from the print controller, as you can adjust halftone, rendering intent, gamma and color profiles for various tests.
              • Dwylie
                • Mar 2020
                • 7
                I am waiting for a new LSU board to come and will try that. I will post my findings. Thanks for all your help with this issue.
                • doyvid
                  • Aug 2019
                  • 56
                  If by any chance you're talking about the little board attached to the LSU with the ribbon connector, double check the parts guide and make sure you didn't order CPWBX2161DS51 or DS52 by mistake (6070 series only, and it's wrong anyway). If that board is fried you'll need a whole new LSU, since there's no part number available for the correct board.
                  Be extremely careful with that ribbon connector, it is very fragile..
                  • Dwylie
                    • Mar 2020
                    • 7
                    So I ordered the whole LSU Unit so it came with a new PWB. I just put it into the machine and got the same thing. The only thing I have not changed at this point is the PCU PWB. I guess that will be the next thing I try unless you guys have any other ideas. Thanks in advance for your ideas on this problem of mine.
                    David
                    • Prints Charming
                      • Aug 2019
                      • 189
                      Hi David,
                      3 weeks ago we mentioned that the problem would not be the LSU if the 64-01 tests were OK.
                      I mentioned that 64-05 tests were required to confirm the print controller (MFP Board) was OK. So far you haven't mentioned this being done.
                      There is almost no chance the problem is caused by the PCU board, so don't order that part. The image problem you have is digital, so its coming from a controller.
                      Test 64-05 and see if you have the same problem. This test comes from the MFP board. That is where your problem most likely is, as you've confirmed the LSU is OK with the internal LSU controller tests in 64-01.
