Sharp easy mode
  • Hansen88
    • 1036
    Sharp easy mode
    I like the normal screens and customers who have had sharps before like the regular screens better also. I have found how to have machine default to the regular copy screen.But I am wondering if there is a easy way to turn off the easy mode alltogether. I dont seem to see a setting for this.
  • Nachoman4life
    • Oct 2007
    • 212
    Re: Sharp easy mode
    Edit the home screen, delete the easy copy/fax icons, move the regular copy icons back to the 1st screen. Edit home is in the action panel on the right hand side of the screen.
    Where the heck is my spring hook?
    • spanky
      • Sep 2012
      • 468
      Re: Sharp easy mode
      To remove the easy settings from the top of the home screen you can also open the settings/common settings/operation settings/mode key display setting/ and at the bottom of the page uncheck the box for "display mode keys on home".
      • Hansen88
        • 1036
        Re: Sharp easy mode
        Thanks for the replies guys. That is the same as I was doing. I was wondering if I was missing like a on/off type setting. Will continue doing it the same as I had been.
