ARM451U does not recognize usb port
  • akbareshghi
    • Sep 2010
    • 261
    recently in windows 10 64bit os , my MFP machine entered into problem which can not detect printer automatically while before when i connect the usb cable , then inside control panel>devices and printers automatically detect the virtual printer port for printer
    my other printer have been detected by windows and being in health condition and print
    but for ARM451U , this problem appeared
    i think this problem perhaps is due to my firmware or maybe disappear through reset it
    it changed my usb socket but my problem still exist
    thanks for your suggestion to resolve my problem
    Color printing with lowest cost per page is my love.
  • Prints Charming
    • Aug 2019
    • 189
    Re: ARM451U does not recognize usb port
    I highly doubt the problem is the MFP.
    You can confirm this by connecting the MFP to another computer or laptop by the same USB cable. It should detect OK.
    The ARM451U definitely has Win10 drivers. Does the printer appear in the Control Panel but shows an error, or not appear at all?
    I believe the problem is going to most likely be the USB controller on your computer, or the classic Win10 corrupt printer registry, which happens especially on USB devices which are disconnected & reconnected over and over. You can look up many websites on correcting this problem on your computer. Be careful though, you're playing with the windows registry!
    The simple test is to connect the MFP to another computer and check detection. There is no MFP firmware to fix this issue for this model. USB problems are almost always a problem on the computer, not the MFP. And yes, this can still happen despite other printers working on USB perfectly fine.
    • akbareshghi
      • Sep 2010
      • 261
      I connect the MFP to another laptop by the same USB cable. It did not detect usb port.
      I have and install the correct windows 10 64 bit driver.
      i thinks this problem happens on USB devices when because of interrupt and delay for transfer print pages via usb and i was forced to disconnect & reconnect the usb cable over and over and after that the delay or not sending print had been solved
      if i can not solve this not detection of virtual port for usb , can i install network card on the pwb board to use and utilize the network printing
      thanks for your helpful guidelines
      • akbareshghi
        • Sep 2010
        • 261
        I doubted to Sony CR261... battery on PWB board
        some other causes need inspecting
        • OlliK1969
          • Nov 2016
          • 310
          Hi
          is the usb port activated in system ??
          • akbareshghi
            • Sep 2010
            • 261
            Originally posted by OlliK1969
            Hi
            No, no port of MFP has been recognized and detected by windows 10
              Bet the problem is in win10.
              Have you created a new usb port in win and then connected the printer?
                He asked if the usb port on MFP is active. WIN10 is really bad when installing updates. Take a different pc.
                Hook up to MFP. Does it see the MFP?
                Are you sure you don't have a WSD (windows stupid driver) installed?
                • akbareshghi
                  • Sep 2010
                  • 261
                  i Take a different pc but this problem ie not seeing the printer and usb port does exist
                  Hook up to MFP. Does it see the MFP?No
                  Are you sure you don't have a WSD (windows stupid driver) installed? i install the correct driver on windows 10
                    How are you hooking it to the pc?
                    And you still haven't verified IF THE USB PORT IS ACTIVE?
                    You are not giving all the answers you have been requested to provide.
                    I am about done with this thread.
                    • akbareshghi
                      • Sep 2010
                      • 261
                      [QUOTE=Phil B.;1473991]How are you hooking it to the pc? yes
                      And you still haven't verified IF THE USB PORT IS ACTIVE? Yes through custom setting key menu
                      possoble causes of above problem?
                      expire and running out battery in the printer board
                      socket B failure
                      software failure
                        [QUOTE=akbareshghi;1474777]
                        socket B failure
                        software failure
                        I know I have asked MULTIPLE TIMES. -= HOW =- are you connecting to the copier USB -= OR =- CAT5 ETHERNET.?
                        Sounds to me you don't have the skills or you are just refusing to give proper info.
                        Could the usb be disabled because the NETWORK PORT is active?
                        • akbareshghi
                          • Sep 2010
                          • 261
                          [QUOTE=Phil B.;1474996][QUOTE=akbareshghi;1474777]I know I have asked MULTIPLE TIMES. -= HOW =- are you connecting to the copier USB -= OR =- CAT5 ETHERNET.? Through usb
                          My board does not have Network interface unfortunately and
                          the NETWORK PORT is disabled but Usb port is active in machine
                          • akbareshghi
                            • Sep 2010
                            • 261
                            Please introduce some suggestion or solution or alternative to solve this problem
                            thanks a lot
                            • Jack79
                              • Jul 2014
                              • 312
                              Make sure the usb port is enabled in the settings. Try different printer A to B usb cable.
