Status Message by E-mail Request Setup
  • boutn
    • Jun 2016
    • 547
    Any of you have any idea what this does exactly?
  • spanky
    • Sep 2012
    • 468
    Re: Status Message by E-mail Request Setup
    You set the schedule you want and the email address to send the information to.
    The information it sends is the page counts, if you have a customer that is charged by the page count you can get them sent to you by the machine.
    • mansart
      • 852
      I believe(I have never used) this will allow you to request the status page via email.
      Standard set up tells the machine to send a status message at a predetermined interval.
      With Status Message by E-mail request, it will send a status report when requested by email.
      So you have to set up an email account for the copier to monitor. Example sharpcopier@mydomain.com
      When the copier receives an email with a request for status the machine will reply with a status page.
      I'm not sure of exact phrasing that must be used..... my assumption is that a particular phrase must be sent in either subject and/or body of email in order to trigger this response.
      • Leebs14
        • Feb 2014
        • 457
        I use this function on all my sharps in the field, works very well, If you do set it up to receive meter readings then remember to set up for both schedule 1 and 2 and choose dates 3 days apart to straddle the weekends. We set our machines up for the 23rd & 26th of every month, so if the 23rd is on a weekend then the 26th will be a work day, hope that makes sense.
        also on the newer machines MX2640 type onwards as you can also specify alert emails for low toner etc, which is useful too.
        happy to help with set up instructions if you need them.
        • doyvid
          • Aug 2019
          • 56
          The alerts are useful, but I wish the machines would email the entire 22-6 report.
          • boutn
            • Jun 2016
            • 547
            I know how to set up the counters to email and such,
            the thing i want to know is what the "advanced" tab does, as mansart understood correctly...
            • Chriss
              • Jan 2021
              • 5
              Has anybody found out something?
              We recently became Sharp dealers, so I'm going around in the menus so that I get to have an overview of how they are structured.
              I saw that Status Message by E-mail Request setup page, compiled all the POP3 fields requested but can't find anywhere wich string I need to send to the mailbox.
              I've tried things like "devicestatus?request=supply" in the mail object or body (as I found out on a Ricoh manual), I can see that the mail gets automatically read, but I get no response.
              Obviously SMTP is correctly configurated and it works with no problem.
              I even asked the guy who came to our office to show us the functions but he didn't even know what that was.
              This would be very helpful given that Sharp doesn't offer any remote portal diagnostic.
              Thanks in advance, cheers
              • mansart
                • 852
                ...given that Sharp doesn't offer any remote portal diagnostic.
                MICAS | Document Systems | MFPs | Sharp for business (sharpusa.com)
                • mansart
                  • 852
                  Sharp Remote Device Manager - SRDM2 - Soluzioni - Soluzioni documentali - Product Details Device Management
                  I don't see any reference to MICAS on Sharp Italy page???
                  • Chriss
                    • Jan 2021
                    • 5
                    Hello mansart,
                    I know those options, but:
                    1. From Italy we can't access SharpUSA (therefore no MICAS, I've already been trying to find a way to install it but didn't find a way to)
                    2. SRDM installs a WebServer on a local machine in the customer site, so it's not really remote (in case we want to check on the machine status from our HQ, we would have to call the customer and connect to the machine ecc.) -> I've already installed that in our network, so I tried how that works.
                    With remote portal I meant something like Konica Minolta's CS Remote Care, Kyocera's KFS or Epson's ERS.
                    We use exports from those portal to import status on our custom made CRM.
                    We often use Print Fleet Optimizer on customers whose machine does not support direct connection to a in-cloud portal, but that option means that we have to install a program on a Windows machine (so, no luck with MacOS environments)
                    Yes, I know that mail reports can be configured and we are already working on a way to import these mail reports too, but it would be useful to have a real-time status report when needed (and to say it all, I've been trying to find some info on this function for days and now has become more of a personal matter )
                    Thanks for the answer and sorry if I wasn't very specific before.
                    Cheers
                    • mojorolla
                      The Wolf
                      • 2611
                      I played with this a few years back. Basically, it allows a plain text email to be sent to the machine. That email and the variables within will let the machine respond back with the information requested. Think of it as on-demand meter reads and status messages. From what I remember the documentation was awful and configuring the email client and machine was more complicated than setting up the standard daily/monthly alerts.
                      • Chriss
                        • Jan 2021
                        • 5
                        Yeah, I figured out that It was something like that. But I was wondering if anybody knew how to actually request the status via mail.
                        Where you able to?
                        Cheers
