MX4071 PHOENIX II SERIES E7-90 codes
  • mloudy
    • Oct 2015
    • 777
    #16
    Re: MX4071 PHOENIX II SERIES E7-90 codes
    You will next be told to do a packet capture using an old style hub instead of a switch and analyze with Wireshark. I have idea what this means and we have never done it but it has been mentioned to us several times.
    • GJG
      • May 2021
      • 2
      #17
      Long time Sharp tech/ new user looking through this. Any updates to this out there?
      • jon jennings
        • Aug 2011
        • 51
        #18
        Hello, KDR363
        I am wonderring if there was a resolution to this problem.
        • GJG
          • May 2021
          • 2
          #19
          Originally posted by jon jennings
          Hello, KDR363
          No resolution from my point of view. Still seeing e7-80 and e7-90/power issues on the mx4070 type and 4071 type. Some intermittent, some more persistent.
          • copiertec
            • Jan 2016
            • 2191
            #20
            Is it just on the 40 ppm and higher? Or are the 35ppm and lower having these issues as well? If it's power related would putting them on a dedicated 20amp outlet resolve the issue?
            • kdr363
              • Apr 2019
              • 63
              #21
              Hello, KDR363
              No resolve. However, I've had 2 problem machines, that coded about once a week, hasn't coded in months, no idea why. Checking my records, my fleet overall has decreased in the number of E7-90 codes. Firmware corrections that Sharp doesn't mention? IDK
              • Craigcul
                • Aug 2017
                • 70
                #22
                Hi I have seen this error caused by power failure it seems to cause errors in the hard drive it then start throwing up this error code
                But I have seen that suddenly sharp changed to a new manufacture of the power supply, I wander.
                Sent from my iPad using Tapatalk
                • kdr363
                  • Apr 2019
                  • 63
                  #23
                  Firmware is coming for this problem. But you didn't hear it from me.
                  • mloudy
                    • Oct 2015
                    • 777
                    #24
                    Released yesterday. For this series and the mono.
                    • OlliK1969
                      • Nov 2016
                      • 310
                      #25
                      Hi
                      firmware 05.00.Z2 is available
                      • kdr363
                        • Apr 2019
                        • 63
                        #26
                        The firmware update has been 100% effective on the dozen or so machines having this problem, which is great, but frustrating at the same time as to why it took almost 2 years of jumping through hoops to finally get a resolve.
                        • boutn
                          • Jun 2016
                          • 540
                          #27
                          Any chance this is coming for the MX4070N/V also?
                          • kdr363
                            • Apr 2019
                            • 63
                            #28
                            I can remember the earlier versions having E7-80 and 90 errors. They too were corrected with firmware a few years ago.
                            • boutn
                              • Jun 2016
                              • 540
                              #29
                              I guess thats a no/i dont know?
