Sharp ARM277 part number?
+ More Options
Posts
  • repeatcopiers
    • Sep 2008
    • 591
    I'm looking for the 'ratchet' type gear that is located on the back of the copier that the fuser unit connects to. My customer has this as a backup copier and I don't have a parts book for it. Any help would be appreciated. Thanks, Debi
  • OMD-227
    Latest part number here in Australia is:
    NGERH0090QSZ1
    Stripped tooth gear. It's a pretty common issue.... I'd order more than one if I were you. You will see this one again.
    • repeatcopiers
      • Sep 2008
      • 591
      Thanks so much!
      • repeatcopiers
        • Sep 2008
        • 591
        Sharp ARM277 gear
        My tech says this is not the gear he is looking for. He says he needs the gear that is touching the gear on the roller and it has teeth on both sides. Any idea?
        • CopierTechofOmens
          Agitating Artificer
          • 268
          The new part has been updated. It looks different. If it's not that gear a better description is needed.
          sigpic
          • repeatcopiers
            • Sep 2008
            • 591
            Ok thanks, that explains why it didnt look familiar. Much appreciated!
