Administrator password
  • Momiowilove
    • Sep 2019
    • 63
    Good day to all. Im having a problem with thr sharp mx 4110 administrator password. I try the five 1's five 0's and 12345. And also i try the dipswicth in the system board. And i try to reset the admin password. It keeps asking administrator password. How can i solve this problem. And also i try the admin, user and sysadmin password it always asking admin password
    Sent from my RNE-L22 using Tapatalk
  • CroceL
    Sharp / Brother Tech
    • Jun 2020
    • 60
    Re: Administrator password
    Solution from another Thread/User
    " Go to another machine (MX 5141) model doesn't matter. Go to Storage backup. Choose User Register Information. Create backup. Go to the MX 5070, type IP address. Go to (IP address /service_login.HTML), Password is service. Go to device Cloning. Send the backup you made to the machine and the password will be reset. "
    Never tested it myself, but some say it works fine.
    Good luck
    • Momiowilove
      • Sep 2019
      • 63
      What is the default ip of the machine bcos the machine comes from a company that uses a card key the ysoft software.
      • JLSam
        • Jun 2015
        • 605
        It works but I think we should private message that information...
        Sent from my GM1917 using Tapatalk
        • CroceL
          • Jun 2020
          • 60
          @Momiowilove
          You should be able to "Print List" without Adminstrator login, otherwise ask their IT department or connect to a PC from the customer and look up the IP in the driver.
          @JLSam
          Oh sry I'm kinda new here, is there a Guideline/Ruleset where I can lookup whats allowed to share public?
          • Momiowilove
            • Sep 2019
            • 63
            I can print usiinh the service mode list print sir. i tried to input the ip address in ipaddress.login/hmtl its not working. The machine comes with a ysofft application and id system. And i saw a application named sharp osa. How can i disable it sir
            • Momiowilove
              • Sep 2019
              • 63
              The problem was solved we call a distributor technician of sharp. They didn't give us any hint after the technician solved the problem. Thank you to all
